uh oh
  • ScottsXS
    • Sep 2005
    • 169
    • Demotte, IN
    uh oh
    Tach not working....regulator hot to touch....very hot.......but she's got 13.74 volts @ the battery running I am at a loss checked plugs and connections. Any help is great thanx
    when in doubt...get a bigger hammer
    '78 XS11e, '79 XS11sf,'81 Mazda RX7, '83 XJ650lj Turbo, '95 Ford F150, '93 Chevy K2500, '04 Honda Pilot,
    '89 Arctic Cat Wildcat, '89 Arctic Cat El Tigre 530, '81 Arctic Cat Trailcat 340, '79 john deere trailfire 440,
    '78 Cadillac Seville
    Don't steal the government hates competition
  • Varnae
    • Aug 2008
    • 318
    • Noblesville, IN
    Just by your first two symptoms I'd have to go with that regulator either bad or on its way out. You seem to have good voltage but if it's heating up like to where it's hot to the touch that's a bad thing.
    just my 2 cents
    If you don't own a fire extinguisher, do me a personal favor and go purchase one... immediately.
    1980 MNS
      Check the big white connector behind the fuse block. That's a common place for corrosion and shorts, causing heat, melting, and Tach failure. Mine melted so bad I had to crush the plastic to get the wires out.
      • tarzan
        • 1700
        • Chandler,Az.
        Catotonic said-
        +1
        Start there.I had one of those wires burn to an exhaust pipe once.
        And it is common to have problems at that connector
        **Hey Tarzan, not sure what button your pushing to QUOTE the text, but it's not correct, it comes out as an HTML code, and you get that funny sidescrolling text window. I editted the above inserting the "QUOTE" codes instead! T.C. **
        80 SG XS1100
        14 Victory Cross Country
        • ScottsXS
          • Sep 2005
          • 169
          • Demotte, IN
          Update also no turn signals, horn, idiot lights.........but head light, brake/tail light work
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            Have a look at the fuses ,signal fuse will be blown if there is nothing else wrong.
            BDF Special
            • ScottsXS
              • Sep 2005
              • 169
              • Demotte, IN
              so far all fues and connections check out ok the only plug i havent checked is the one behind the headlight for the ign switch btw this is my sf not the e
                • 7793
                Check the STATIC voltage at all connectors. I DID have a wire get "hot" INSIDE the harness, and melt to a ground wire! that one took about three months of running "as is" before I was able to find it. I would also check and clean ALL ground connections. The MAIN harness ground is at the.....Regulator!
                Keep us informed, and we can try to halp from far away, so we DON'T hear the words I know you are using!
                • ScottsXS
                  • Sep 2005
                  • 169
                  • Demotte, IN
                  well update.........shes fixed. looking,looking,looking and i dropped my test lite which bounced off the fuse panel........well low and behold the signal fuse not only disintagrated. but so did the clips for it. i spliced in a single fuse holder temp till i can get a new fuse panel. now if i could just get this idle issue fixed thanx all for the help.....and i only dropped a couple of "F-bombs"
