Coils
  • Varnae
    • Aug 2008
    • 318
    • Noblesville, IN
    Coils
    So other than MikesXS, does anyone have another source for coils? I'm pretty positive mine are bad and it seems MikesXS is out of the black coils. They have the green ones but I can't see myself spending that much on them just yet.
    If you don't own a fire extinguisher, do me a personal favor and go purchase one... immediately.
    1980 MNS
    • 7604
    You can look at some of the newer automotive coils. Hit a junkyard and look under the hood for an engine like the Subaru that uses a waste spark coil. You WILL need to bring a VOM with you to check the resistance. If it's about 1.3, you will need a ballast resistor. ~3 Ohms, should be good. Any more than ~4 Ohms, and you should NOT use them.
    Don't know if this helps, but it IS another way to try and find a "hot" coil cheap.
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      I had the same idea but haven't tired it yet. I drove a Suby for a couple of years and those coils sure looked bike like...
      Geezer
        • 8634
        Save up a little and get some Accels. You won't be sorry. JMHO
        โ˜ฎ
        • jwoell
          • 63
          • Wichita, KS
          Partsnmore.com has the same coils as MikesXS
          I needed another one of the same coils you're talking about from MikesXS (I busted one, don't ask). Anyway, he was out at that time too. I searched for the part number and found out that Partnmore.com sells the same ones, part number 17-6803. So I picked one up from there and it was exactly the same, worked perfect.
          Here's the link if you need it...
          Partsnmore offers premium motorcycle and ATV parts for Honda, Yamaha, Kawasaki, and Suzuki models. Shop top-quality OEM replacements, aftermarket, performance parts, and accessories at unbeatable prices. Enjoy fast shipping, expert advice, and trusted products to keep you riding smoothly. Shop now for the best deals!
          It's listed a little ways down the list...
          '81 XS11 SH (XSelsior)
          • tw1980
            • Apr 2009
            • 662
            • Bend OR
            Just installed green mikes xs coils today.Went for a test ride about an hour ago.Save your pennies and get the green ones. I would recommend you stay away from junkyard coils.Our tci units are expensive and getting harder to come by.Terry
            1980 special (Phyllis)
            1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
            • kirmit77
              • Mar 2009
              • 464
              • Kingwood, TX
              Out of stock there too.... bummer
              Austin Ingalls
              MIDNIGHT FURY
              XJ maxim rear air shocks
              KERKER 4-into-1 exhaust
              Pod Filters
              Money pit.......
              BLACKED OUT
                Even more so for the 81 and the 82 XJ... Each one year specific IIRC. I believe the 78-80 are interchangable though.
                • TADracer
                  • May 2006
                  • 1417
                  • Kenner, Louisiana USA
                  Well I cannot speak for Mikes green coils or most other aftermarket coils however, I have a pair of 3 ohm Dynatek Performance DCI-1 coils with 8.8mm Accel stainless steel wires. They will not make more power for you but will definately unlock any potential power you may have. You can feel the difference both in unlocked performance and the fact they will knock you on the ground if you happen to get in the way of the spark path.
                  Mike Giroir
                  79 XS-1100 Special
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    alternative coils
                    ZRX1100 coils......
                    MDRNF
                    79F.....Not Stock
                    • superxs
                      • 19
                      replacement of the wires
                      Hi,
                      Maybe can you send me a mail address so I can send you pictures of the pieces ans also an other way to replace the "wires" of the coils. I've descript it in a word document. If you're interested...... It works very good. Generally, the coil(bobine?) is in a good state but the wires become ""marshmallow" )))))))))) )))))))))). I've made it on my XS
                      Greetings from Belgium
                      Alex
                      PS: sorry for my bad Us speaking
                      • dbeardslee
                        • Nov 2007
                        • 4385
                        • Maineville, OH
                        Z1 Enterprises sells a set of 3 Ohm Dyna Coils for our applications. Unfortunately they're nearly as expensive as the green monsters, but only put out 30k volts. The green ones put out 45kv at 12.5 volts input, and 75kv at 14 volts input.
                          Hey SuperXS,
                          You speak better English/American than some natural Americans do!! Thanks for the offer of the replacement of wires in old coils writeup, but we already have one in the tech tips, complete with pictures and everything!
                          Well, I'm glad that the green ones are performing well for you all. I still have the regular 35Kv black MikesXS/PartsnMore ones that I put on when I did the tech tip, and they have worked flawlessly for several years now. I've read where some folks oopsed and tried to SOLDER their wires to the terminals.. I believe they(MikesXS) state to NOT solder the wires to them, but use slip on connectors. Sorry to hear that they are becoming out of stock for both Mikes and PNM!
                          Probably any aftermarket high output(double OEM of 15Kv or more) will provide the enhanced performance, just depends on how much you want to spend for it. I know mine starts up much quicker and easier, and just has plenty of power. I didn't really notice any better mileage though! YMMV!?
                          • Lamric
                            XStremely XSive(Deceased)
                            • 410
                            • Kenley, Surrey, England
                            'nother option is Honda VF1000 coils. Photo's and more details here
                            Brian
