What tires do I use??
    How many hairs just stood up on the back of most of your necks when you read this.. lol.
    But seriously.. I read this in the manual...
    Does that tire size for the front tire 3.50 H19-4PR mean a 4-ply radial or simply 4-ply RATING? Since the "R" is uniformely known in the tire world to stand for radial, would I be wrong in presumming this is what they meant? What about the obvious OMMISION of a "B" for bias tires?
    We've all heard the theories about mixing radials and bias plies on a bike.. but we've also proven a lot of theories wrong on here. And what about both tires being radial? Does anyone have this experience with their bike.. and to what noticeable effect?
    WARNING!!!
    Please don't turn this into a discussion about a favored BRAND or MAKE of tire. I'm simply talking bias or radial type of any/all tires.
  • Bigfoot
    XS-XJ GURU
    • Sep 2005
    • 1422
    • Kansas City, Missouri
    Interesting, I was always under the impression that Bias ply were recommended for these bikes. Not sure where I picked up that info, but that is what I thought.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
    • hamjam
      • 1003
      • Toronto ontario Canada
      I don't think radials were available for street use until '86 ,so i think it stands for rating
      Seamus ร“ hUrmholtaigh
      Niimi Moozhwaagan
      and SOXS
      2008 Nomad "Deja Buick'
        With tens of thousands of miles on both riding my XS and my Honda ST, wouldn't think radials would cause any issue with the XS. You would want to use same manufacturer and model of tire though. All radial designs of bike tires are NOT the same and WILL cause handleing issues if not the same front and rear. As far as bias ply, our XS's don't seem to mind mixing and matching as long as the tread is good. Radials I suspect would want to be run as mated on the XS's also. Advantages of radials I have noticed on my other bike being a bit less heat build-up, tracks on un-even surfaces perfect,(no wiggle) and a bit more even tire wear. Total mileage difference, little if any. That's just my personal experience.
        • Guy_b_g
          • May 2007
          • 790
          • Beverly Hills, Florida
          I've never seen radials sold in the sizes these bikes use.
          Guy
          '78E
          • red bandit
            • 950
            • central michigan
            One's that hold air!!
            What he said. 4 ply rating. Didn't think radials were avalible for xs's back then.
            79 SF parts bike.
              Size does matter!
              Hey Tod,
              A search for "Radials" revealed several threads about this, here's one which confirms what Guy stated about how we can't get Radials that will fit our rims! http://www.xs11.com/forum/showthread...hlight=radials
              Shall I close this thread now?
                • 7608
                3.50 H19-4PR
                This is a 3.50" by 19" "H" speed rated front tire. Because the bike is heavy, you could NOT use the 2 ply rating tires that are the same size, used on LIGHTER motorcycles. You needed to use a 4 Ply Rating tire for the replacement. As stated, these machines pre-date Radial tire technology for motorcycles.
                • 79XS11F
                  • Jul 2006
                  • 3563
                  • Ottawa, Ont. Canada
                  According to this site on tire markings and what they mean, that "R" even at the end but preceding the speed rating still means radial tire??
                  We have over 500 Tire Reviews from drivers just like you, We're your trusted source for American consumer tire test and ratings
                  I however, have never had a radial tire on my bike ether front or back or both so this is all I can offer.
                  Rob
                  KEEP THE RUBBER SIDE DOWN
                  1978 XS1100E Modified
                  1978 XS500E
                  1979 XS1100F Restored
                  1981 Suzuki GS1100
                  1983 Suzuki GS750S Katana
                  1983 Honda CB900 Custom
                  • Guy_b_g
                    • May 2007
                    • 790
                    In the days before radials (BR)..."R" could not mean radial...key here is not "R", but "PR" "ply rating" (I'm guessing here..but it definately is about the load rating) but we know for a fact it can't mean Radial as there were none available for street bikes at that time.
                    Guy
                    '78E
                    • Guy_b_g
                      • May 2007
                      • 790
                      Aha...found it..PR is indeed "ply rating" as you can see here: http://www.maxxis.com/MotorcycleATV/...re-School.aspx
                      Guy
                      '78E
