Who has brought the front end up (wheelie)?
That's a good idea anyway. So is replacing the coils. I was going about 100 miles per tank prior to new Mikes XS coils, now I hit 117 sometimes. But I wouldn't think there was anything wrong with your bike besides typical age stuff. These are long heavy bikes. In stock form I wouldn't call them easy to get up. It could even be in the drive train. I know my stock clutch springs were jello when I first got the bike. I wonder if a little clutch slippage makes it a little harder to get it up also.79 XS11 specialComment
Can I change my answer?
I was having problems with a little oil in the airbox over time so I rerouted the air hose and put a breather on the end. I then cleaned the air filter and housing. I then rerouted the fuel hose from the petcocks to my shut off valves (I found the hoses kinked a touch). I then sync'd the carbs with my homemade sync gauge. I then checked pickup coil wires and found them to be good. Finally, I trimmed 1/4" off the spark plug wires that go into the boots.
The result:
While accelerating in 1st and if I jerk the handle bars back, I can get the front tire off the ground like an inch or two (that's with the 850 final drive, fairing, and 3/4 tank of fuel). It's not a real wheelie but at least I can get it off the ground. I kinda wish I did all the above things before I did the final drive swap to feel the acceleration of stock gearing, but I'm too happy with the 850 drive to go back.1980 XS1100 Standard "Touring"
Fairing, Trunk, and Bags
850 FD
Fork Brace
Progressive Front Springs
Engine Guards w/Foot Pegs
Oil Cooler
Throttle Lock
Uni Air Filter in Airbox
2009 Suzuki Bandit 1250S ABSComment
That's good to know. I have that 850 midnight rear drive on the way and I was afraid that I would loose too much take off power...
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
Geezer...
All my unicycling has been done on a 750 final drive. Once you get yours installed.. after a couple days, you'll be used to it, and love it just like the rest of us.Try your hardest to be the kind of person your dog thinks you are.
I probably shouldn't......
I'm hesitant to post this, but here goes!
Here's a little clip I put on Youtube. It's been pointed out that because I have the 4" over length front fork tubes that my bike is more primed to do wheelies!? Also it has the little big bore kit in it, so it does have a little more OOMPH power! And it also has the STOCK Final Drive, I like revving!
Also my luggage/saddlebags are lightweight aluminum, only weigh about 20 lbs max, so no real extra leverage there!!
Godzilla Roars
The thing is, folks also look at my other clips, from a few years ago when I did a few runs at the local race track..POOR PERFORMANCE I must say!!
But this is where I did one hell of an unexpected WHEELIE!
I had already made a first run next to the Harley with the Screamin' Eagle kit, and was wanting to try to do a stronger run. I revved it up to 5K, and was trying to take off, fanning the clutch, but was wearing very bulky gloves, and ended up dumping part of the clutch lever, which then brought the front end STRAIGHT UP!!
Thank goodness for long legs, was able to hold on, and turn the throttle down and brought it back down and then finished the run. But that's why the guy at the starting line was making those wheelie type movements of his arms in the air when I rolled up to the line for yet another try!
Have a good laugh on me!!
T.C.T. C. Gresham
Don't feel to bad TC, first time we took the Cutlass to the strip and unbolted the exhaust but still had street tires on it. I got to the line, hit the line lock on the front brakes and cranked the RPMS up to about 2500 on the 502 with about 3k lock up torque converter, tires were just ready to turn over. Lights ran down and I relased the line lock and stomped the pedal and proceeded to eat the tires up. I shifted the thing up into second, then third and still no grab and came REALLY close to the wall. Had to come all the way out of it, let it grab and then make the rest of the run in third. Ended up at 15.28 in a proven 12.25 car.
Never again will I uncork the exhaust without the big meat in place.Life is what happens while your planning everything else!
78 XS750Comment
A couple times on each bike......mostly oppsies comin off the linewhen in doubt...get a bigger hammer
'78 XS11e, '79 XS11sf,'81 Mazda RX7, '83 XJ650lj Turbo, '95 Ford F150, '93 Chevy K2500, '04 Honda Pilot,
'89 Arctic Cat Wildcat, '89 Arctic Cat El Tigre 530, '81 Arctic Cat Trailcat 340, '79 john deere trailfire 440,
'78 Cadillac Seville
Don't steal the government hates competition
Does this count??
Does this count??
78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
Hey foreda,I think you should remove that picture.It may void your sears warranty.
Terry
1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner modComment
That's not what most bikers mean by a CHOPPER!
T.C.T. C. Gresham
78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
or how bought this (more recent with the 4 into 1)
[IMG]<a href="http://s404.photobucket.com/albums/pp128/daddyp-xs/?action=view¤t=import25044.jpg" target="_blank"><img src="http://i404.photobucket.com/albums/pp128/daddyp-xs/import25044.jpg" border="0" alt="another one"></a>[/IMG]Comment
