Last weekend Russ79, ZombieRob and I were working on Robs bike and cleaning the carbs. Found that all four of the mixture screw tips were broken off and stuck in in the carb bodies. We tried everything we could think of and all of the tips that we found here on the site with no luck. Russ called Trbig for some ideas. As per his suggestion, Russ put them in the freezer for about an hour. Took a o-ring pick and they popped right out. Once again Tod saved the day.
Broken mixture screws - removal
Don't thank me.. I'm just a forum slut that happened to read about the idea here...
The thanks goes to TDodge7.. it was his idea. Glad it worked though...
*Crashed/Totalled, still own -
I wonder if this trick would help with stuck pilot jets...?'81 XS1100 SH
Sep. 12th 2015
RIPComment
