Broken mixture screws - removal
  • Filter
  • Broken mixture screws - removal
    Last weekend Russ79, ZombieRob and I were working on Robs bike and cleaning the carbs. Found that all four of the mixture screw tips were broken off and stuck in in the carb bodies. We tried everything we could think of and all of the tips that we found here on the site with no luck. Russ called Trbig for some ideas. As per his suggestion, Russ put them in the freezer for about an hour. Took a o-ring pick and they popped right out. Once again Tod saved the day.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
  • #2
    Don't thank me.. I'm just a forum slut that happened to read about the idea here...
    http://www.xs11.com/forum/showthread.php?t=23004
    The thanks goes to TDodge7.. it was his idea. Glad it worked though...
    • #3
      I wonder if this trick would help with stuck pilot jets...?
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • #4
        you're welcome
        it might work for jets too , never tried , all mine were out of the carbs by the time i threw em in the freezer .
        • #5
          That being said, I wonder if a localized shot of freeze would work? I use 'air in a can' in electronics troubleshooting, helps identify flaky components. Turn it upside down and it will freeze the sh--t out of anything. JAT
