Would i need to replace the springs with shorter ones or can i crank down the stock springs? Cause i am collecting parts for the bobber xs11spec and was hoping to find a shorter spring or see if someone knows how to turn the stock ones down. It looks like that have an adjustment on them to compress them is that correct or am i looking at it wrong? Anyways i want to push the wheel closer to the frame and seat area and keep the semi soft ride quality. If anyone knows how to do this or whatever, some info would be extremely helpfull thanks. Josh.
lowering the rear?
You would have to install a set of shocks that are shorter eye to eye than stock . You can find good deals on Ebay lots of 11" to 11.5" for sale that would drop the rear by 1.25" to 1.75" .BDF Special
