coil cables
  • JC FC
    • Mar 2009
    • 49
    • Salt Lake, UT
    coil cables
    so my from my coil cables, two of the plug connectors (the rubber thing that connects the cable to the plug) are broken, and i accidentally pulled them off while messing with them...do i need new coils? can i just get new plug connectors, do i need a splice thing? not sure what to do lol
    and i pulled them out...not unscrewed ( i guess you can do that?)
    '79 XS1100SF
    • 8930
    Those are replacable, the cap ends, they just screw on. NGK makes them. Get 'em from Dennis Kirk or even an auto parts store that's good with foreign parts could get them. Cyls 1-4 use the 90* elbow type, where cyls 2-3 use the 120* elbow type. 5K ohm.
      You are still unscrewed!!
      IF they the stock connectors, chances are if you look inside where the cable goes you will see a screw in the center. Looks like a sheet metal screw down in there. You porbably just need to cut a small amount off the end of the wire and then push back into the boot while turning the boot so the screw bites into the wire.
      • JC FC
        • Mar 2009
        • 49
        • Salt Lake, UT
        two of the caps are busted...so ill just cut a little bit off the end of the cable (to make sure i have connection) and buy the new caps.
        thanks for the help guys!
        '79 XS1100SF
