vht paint for pipes?
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    i've lost my patience on ever finding a set of black pipes for my mns and my 4 into 1 look like ****e, so i figure on gettin a chrome set of originals [4 into 2] sanding and painting with vht black paint. now i figure someone on this site has already done this, so i'm lookin for info on how it turned out. i'd really like to know which paint is best. any help appreciated
    redbone
    1980 mns 1100
    testing 1-2-3
    1980 1100 mns
    What's wrong with the 4 to 1 that paint won't cover? VHT paint reeks to high heaven and will stink up your place AND the neighbors with the stench. Duplicolor doesn't do that.
    BUT... neither option is going to give you good lasting results if you ride much. Paint just isn't tough enough. What I would suggest is a Jet Hot coated pipe or find someone who can powder coat them.. either of those are almost bullet-proof.
    • Korr
      • Jul 2008
      • 293
      • Torrance, CA
      I have the dupli-color vht ceramic paint. I used it on my rusty headers and with 3 days normal use it cured itself. It' still black, no cracks or chips in the paint. I've had it for about one year and six months i think... I will be painting the engine with it in a few days. Oh btw i like the flat black, but they also have it in the gloss black too.
      1978 XS1100E Standard
      Tkat Fork Brace
      On Hold
      TopCat S.O.F.A. + Fuse Block
      Mike's XS Pod FIlters
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        Duplicolor
        +1 on what Korr said.
        I did the flat black and it has been on there since the pipe chop. IT has rubbed off right right where my foot hits the pipe near the shifter. It's good stuff
        MDRNF
        79F.....Not Stock
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          The powder coating shop that did my frame last year can power coat with high heat ceramic based paint in any color and if silver is chosen they claim it can be buffed up to look very much like chrome. The other colors can also be buffed up to a high gloss finish.
          If chrome was what you really wanted that may be the way to go. If your going to paint them yourself as currently planned I would strongly recommend that you glass bead the pipes and make sure they are PERFECTLY clean for the best and long lasting results.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            If you care to blast your pipes (recommended) and have access to some common spray equipment then check these guys out. Their coatings work but like all coatings, it is in the preparation.
            Mike Giroir
            79 XS-1100 Special
            • Trainzz
              • Apr 2009
              • 215
              • KS
              Heat?
              Does putting a coat of paint on the engine affect the heat transfer/cooling of the engine? My weird science logic says that adding another layer of material to the metal might cause a loss of heat transfer. Living in an area that sees 100+ degrees in the summer on a regular basis, this could be a concern. Seems like adding an extra jacket/coat/sweater to get cooler.
              Lee aka trainzz
              I am my inner child!!
              I have no idea how you managed to make that connection within your brain, but I applaud whatever cellular mutation just took place.
              1980 XS11 Special-"Thunder Pig"
              1980 XS11 Special-"Crazy Trainz" (project bike)
              1979 Xs1100 Standard ( parts,parts,parts)
                It just gives you an excuse to ride FASTER!
                • 03mach1
                  • 114
                  • Cuba, NY
                  I used the Eastwood satin black header paint, they are holding up very well, no chipping, discolor or peeling. These guys have a ton of stuff for auto restoration. Always had good luck with all their products.
                  link
                  Produces a custom look for manifolds, headers; resists up to 1400°
                  Dave
                  • TADracer
                    • 1417
                    Really depends on the kind of paint you use. Most high heat paints are fairly pourous and that will allow heat to expell easily whereas many ceramic paints are less pourous and will actually insulate the part. That is the advantage of using a cermaic coating on a header. It keeps the heat in the pipes making for a more robust exhaust flow (so the experts say). I would go with some sort of a ceramic coating on your header since an ordinary high heat paint probably will not stop rust from happening very long.
                    Mike Giroir
                    79 XS-1100 Special
