Is gas supposed to be coming out of here?
Have you taken the float bowls off? Sounds like the floats are not floating or the needle valves are not seating in their seats to shut off the fuel flow. Seems strange that it's happening in all 4 at the same time, but stranger things have happened.
Did you recently replace the float bowl gaskets? Sometimes they require a bit of trimming to allow them to clear the floats.1980 XS850SG - Sold
-H. Ford -
yup, took the bowls off when i was cleaning them. but i used the same gaskets, they didnt look too bad, and i was pretty sure that they cleared enough for the floats to float. i didnt try to take off floats or anything soooo....idkHave you taken the float bowls off? Sounds like the floats are not floating or the needle valves are not seating in their seats to shut off the fuel flow. Seems strange that it's happening in all 4 at the same time, but stranger things have happened.
Did you recently replace the float bowl gaskets? Sometimes they require a bit of trimming to allow them to clear the floats.'79 XS1100SF
Hi JC,
gas isn't supposed to pour or trickle or drip or even ooze out of anywhere.
Most likely one or more of your floats are sunk or the float valves are leaking or have dirt in them. That lets the gas get too high in the carbs so that it will run out. And down the inlet tract past an open inlet valve and into the engine to dilute the oil. Best you check the oil for being too full, too thin and smelling of gas, too.
Some say a quick rap on the carb with a screwdriver handle or such may dislodge whatever is causing it. That has never worked when I tried it but you may have better fortune. The only thing that worked for me was to remove, dismantle & clean the carbs.Fred Hill, S'toon
"The Flying Pumpkin"Comment
i had no idea!! could this be the problem?? lol'79 XS1100SF
I'd stake my dime on it. You're pouring fuel in the vent and the bowl at the same time.Comment
Good catch Randy! Yeah, the fuel should only be flowing into the lower connections. The upper connections do not get fuel. In my limited knowledge, I'm not sure if that would cause your problem, but it just might.
You say you didn't remove the floats? That tells me you didn't remove and check the needle valve/seat either. Did you pull the jets (main and pilot in each carb) to clean and inspect them? While you're at it, you might as well take the time to clean the rest of it too. All of these things should have been done when you opened them up. Even if you don't find anything, it's a precautionary measure to make sure you won't have to pull the carbs off again sooner than you'd planned.
Be sure you check the little jet IN the float bowl itself. Come carb cleaner and a tiny wire threaded down in the hole, followed by a blast of compressed air should clear out any gunk that might be in there.
-H. FordComment
Hi Randy,
I missed that on the thumbnail then I read your post and clicked on the thumbnail to enlarge it and see the gas tees carefully siamesed to the vent tees. Yeah, that'll do it every time. Really neat connection job though.Fred Hill, S'toon
Just a note. Be sure you have the fuel leakage cured b/4 you ride the bike. I have a Yamaha Triple where the po didn't follow this rule. He had a major flame/burn - you just wouldn't believe the amount of flame this guy survived. The fule line, vacume line, petcock, side cover, tail light lense, and turnsignal lense on the left side were melted. Major rubber melted on the exhaust , and heavy road rash on the right crash bars, and wiped out turn signal front and rear pods and headlight mounting bracket. I don't know if he survived but I would bet he was hurt bad!
Deny1978 XS1100E - The TimeMachine
1980 XS850 Special - Little MoComment
You might also want to check your engine
oil to make sure fuel didnt flow forward into the engine.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
yup, checked for leaks, didn't have it on the bike i was testing the carbs before i did cause i did an attempt to clean them, and wanted to check to make sure everything was good...and it wasn't cause i had fuel leaking out lol. so i shouldn't have any gas in the oil.
but they are on now, no problems...but i dont have spark...well not enough spark...i, gonna go get plugs as soon as the shop opens up'79 XS1100SF
