Installing Dynojet III kit
  • Installing Dynojet III kit
    Does anyone have a Dynojet III kit installed in their 78 or 79 carbs. I have misplaced the instructions and don't know where the needle jet circlip is suppose to go and how to install the air jets that have no threads on them.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    Does this help?
    I picked on the part # and got some instructions. Don't know if they are correct.
    http://www.dynojet.com/jetkits/motorcycle/yamaha.aspx
    Everything on hold...
      Thanks for the link. I was over there yesterday evening and in email contact with Dynojet. They tell me that they did not produce any jetting kits for the 78 and 79 models so the kit is most likely for an 80 model. Given that the carbs between 78-79 and 80 are somewhat different I doubt that I will be able to make use of this kit that came with the K&N POD filters. Looks like I will have to jet this engine the "old school" way.
      Rob
      1978 XS500E
      1981 Suzuki GS1100
        79xs--
        If you are not going to use the kit, PM me, I might be willing to buy it. I have need of one right now.
        Healthy is merely the slowest rate at which you can die
        Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
          For those who have be contacting me to buy this jet kit I have already promised it to the first person who has already asked me for it. this will of course only be if i do not use it or any of it's parts.
          Thanks for the interest.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            Now on a different note. Tech support at Dynojet tells me "its a very very old kit and they do not make them any more and can not offer up any info. So I went through every bag of manuals i have and i FOUND the instructions. It turns out that this kit is actually for a 1980 engine and I do know that the 1980 engine used carbs with different slides and jetting.
            ______________________________________________
            The question is. Other then the drilling of the slides "side hole" because the bit for that is not in the kit anymore, Should the jets still be acceptable to use on my 78 model with 79 carbs? What do you think?
            The other option would be to jet the bike "old school" as per my memory and the guidance from here at channel 11.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
              Hey Rob I still have the drill from my kit I'll measure it if you like.Terry PS I think I still have the instructions too.
              1980 special (Phyllis)
              1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
                Hey that would be GREAT terry and what do you think about using this kit on the 78 carbs? Did this kit work well on your bike?
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                  3/32 dill size.As far how much better do they work?Well I'm not supper impressed.I would have to say I have more top end.But it's been a battle setting up the carbs,and getting the bike to idle and run good in hot and cool weather.Before I installed the kits the carbs were much easier for me to set up. But that might be because of my lack of skill and patients.It would be nice to have access to a dyno for a day.I also found the instructions I don't know if I can scan and post.But if you want them I'll fax to you.Just PM me your fax #.Terry
                    Im running the DJ kit, with pods and a fairly open 4-1 exhaust,
                    im really happy with the set up, the bike has really good accelleration
                    right from off idle, I was chasing the lack off power off idle for a long time,
                    was my inlet valves to tight, something to look at maybe.
                    Also the instructions say 4 turns out on the mixture screws, that was way to rich for me, mines set out at around 2 turns.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
