Installing Dynojet III kit
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Does anyone have a Dynojet III kit installed in their 78 or 79 carbs. I have misplaced the instructions and don't know where the needle jet circlip is suppose to go and how to install the air jets that have no threads on them.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • latexeses
    • Jun 2008
    • 1491
    • California
    Does this help?
    I picked on the part # and got some instructions. Don't know if they are correct.
    Develop a great plan for boosting your motorcycle’s performance by using our convenient, reliable motorcycle carburetor Jet Kits available online. Once you see these kits in action, it will become clear why they’re the products that started the Dynojet fuel tuning legacy. They’ll effortlessly increase power and smoothness throughout the entire rev range. Whether your bike is stock, heavily modified, or created for high-speed racing, our Jet Kits can tune your air/fuel ratio to perfection. Not only will our motorcycle Jet Kits drastically improve your performance, but they’ll also show immediate results. With an increased power output of 5-8% and a fully adjustable design, our kits are the perfect companions to any rider. Expand your vehicle’s performance capabilities today with them.
    Everything on hold...
    • 79XS11F
      • 3563
      Thanks for the link. I was over there yesterday evening and in email contact with Dynojet. They tell me that they did not produce any jetting kits for the 78 and 79 models so the kit is most likely for an 80 model. Given that the carbs between 78-79 and 80 are somewhat different I doubt that I will be able to make use of this kit that came with the K&N POD filters. Looks like I will have to jet this engine the "old school" way.
      Rob
      1978 XS500E
      1981 Suzuki GS1100
      • T99Ford
        • 678
        • Bozeman,MT
        79xs--
        If you are not going to use the kit, PM me, I might be willing to buy it. I have need of one right now.
        Healthy is merely the slowest rate at which you can die
        Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
        • 79XS11F
          • 3563
          For those who have be contacting me to buy this jet kit I have already promised it to the first person who has already asked me for it. this will of course only be if i do not use it or any of it's parts.
          Thanks for the interest.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • 79XS11F
            • 3563
            Now on a different note. Tech support at Dynojet tells me "its a very very old kit and they do not make them any more and can not offer up any info. So I went through every bag of manuals i have and i FOUND the instructions. It turns out that this kit is actually for a 1980 engine and I do know that the 1980 engine used carbs with different slides and jetting.
            ______________________________________________
            The question is. Other then the drilling of the slides "side hole" because the bit for that is not in the kit anymore, Should the jets still be acceptable to use on my 78 model with 79 carbs? What do you think?
            The other option would be to jet the bike "old school" as per my memory and the guidance from here at channel 11.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • tw1980
              • Apr 2009
              • 662
              • Bend OR
              Hey Rob I still have the drill from my kit I'll measure it if you like.Terry PS I think I still have the instructions too.
              1980 special (Phyllis)
              • 79XS11F
                • 3563
                Hey that would be GREAT terry and what do you think about using this kit on the 78 carbs? Did this kit work well on your bike?
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                • tw1980
                  • Apr 2009
                  • 662
                  • Bend OR
                  3/32 dill size.As far how much better do they work?Well I'm not supper impressed.I would have to say I have more top end.But it's been a battle setting up the carbs,and getting the bike to idle and run good in hot and cool weather.Before I installed the kits the carbs were much easier for me to set up. But that might be because of my lack of skill and patients.It would be nice to have access to a dyno for a day.I also found the instructions I don't know if I can scan and post.But if you want them I'll fax to you.Just PM me your fax #.Terry
                  • petejw
                    • 2269
                    • sydney australia
                    Im running the DJ kit, with pods and a fairly open 4-1 exhaust,
                    im really happy with the set up, the bike has really good accelleration
                    right from off idle, I was chasing the lack off power off idle for a long time,
                    was my inlet valves to tight, something to look at maybe.
                    Also the instructions say 4 turns out on the mixture screws, that was way to rich for me, mines set out at around 2 turns.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
