fuel shut off ??
  • chevy_338
    • May 2009
    • 49
    • minnesota
    fuel shut off ??
    i know what 3 of the things mean like off on res but what does PRI stand for sorry i am new to the bike stuff and i am just trying to figure things out
    1980 xs 11 special
    The motor vehicle action sequences depicted in this film are dangerous. All stunts were performed in controlled environments with professionally trained stunt crews on closed roads. No attempts should be made to duplicate any action,driving or car play scenes herein portrayed.
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    That would be Prime
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • chevy_338
      • May 2009
      • 49
      • minnesota
      and what does it do
      1980 xs 11 special
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        dbeardslee said it best in one of his postings...
        Pri, On, and Res. When the handle covers the markings, that's the position it's in. On is the normal running position, flows from the top of the tower (inside the tank) and should shut off the gas flow when no vacuum is present. Pri (prime) flows gas all the time regardless of vacuum from the bottom of the tower, and reserve flows from the bottom of the tower when vacuum is present.
        Prime basically free flows fuel to the carbs...
        79 SF MEAUQABEAUXS
        80 LG Black Magic
        James 3:17
        For those on FB
        • chevy_338
          • May 2009
          • 49
          • minnesota
          thank you very much
          1980 xs 11 special
          • Wildkat
            XS Special Gurette
            • Apr 2004
            • 3416
            you're welcome
            79 SF MEAUQABEAUXS
            80 LG Black Magic
            James 3:17
            For those on FB
            • Crazcnuk
              • Aug 2006
              • 2980
              • Hinton, AB, Canada
              Prime is used mostly for filling the carbs after running out of gas, or draining them for whatever reason.
              Saves having to crank too long.
              '05 ST1300
                Hi chevy,
                your profile don't say, do you have a Special or a Standard?
                both styles of bike have on, reserve & prime fuel tap settings but they work in different ways.
                The Standard has vacuum operated fuel taps that open automatically when the engine starts and close automatically when the engine stops
                except when the taps are switched to prime to let fuel flow all the time.
                The Special is different. It's taps are not vacuum operated and have two outlets.
                One goes straight to the carbs and flows when the taps are switched to prime.
                The other goes to a central vacuum operated "octopus valve" that turns the fuel on and off when the taps are switched to on or reserve.
                Thing is, many POs have deep sixed the octopus as being an unnecessary and failure-prone complication which means you have to remember to turn the gas off just like grandpa had to.
                • chevy_338
                  • May 2009
                  • 49
                  • minnesota
                  Hi chevy,
                  i do not know if it is a Special or a Standard but i do have a vacuum line going to this little thing that my gas lines go to and that little thing has the vacuum line that comes off the block sorry if this sounds weird but i just learning about this bike as i go a long
                  1980 xs 11 special
                    Actually based on him having an off setting tells me it's a special (at least the taps are). Sounds an awful lot like the description of an octy in there also.
                      Yep Std petcocks do not have an OFF setting as the PETCOCK is vacuum operated and off when the bike is off. The Specials that had/have the Octy valve have an off position so you can remove the tank without draining all the gas out. The vacuum shutoff for the special is at the Octy. None the less, in both cases the PRI=PRIME which means it flows fuel without the vacuum source, and it flows form the lower inlet, which means when it runs dry you have NO RESERVE left and just became a member an elite group that gets to push a heavy SOB of a bike to the next station.
                        I was lucky when the happened to me, I was just getting ready to call AAA for my 3 gallons when the freeway helpers stopped by (most urban areas on CA have this during rush hour) and gave me a gallon of gas. It was actually the point that I discovered that the modified petcocks on my original tank had been modified such that after going to reserve I had less than 15 miles of fuel left. Now I have unmodified standard taps and don't know how far I can go on reserve (and I'm not sure I want to know) but I may stick my 1 gallon gas can in the trunk and run it to it dies so I know.
                          • 7647
                          The reserve on a Standard is one gallon+-. I can usually go 20 to 25 miles easily, and I'm only getting about 32MPG at the moment.(carb problems, from day 1) The 80 Mid Night Special will go at least that far, as I'm getting close to 40 MPG with it.
                          • chevy_338
                            • May 2009
                            • 49
                            • minnesota
                            so you saying i have a Special and i can just leave them on all the time cause its a vacuum control so when i park it i don't have to turn the switch off
                            1980 xs 11 special
                              • 7647
                              You CAN, but if you shut the fuel off, that is TWO places it has to leak before going into the carbs.... How safe to you need to be?? It's all about what YOU feel you need to do. I park both my Standard AND the Special without touching the taps. The will be parked for up to a week at a time before riding, and still no problems. I DO keep up on the maintenance, though.
