This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
Paul, the jugs and pistons your getting, are they from an 80 model? If not will these larger DIA valve heads clear the relief's in the tops of the pistons.
I am guessing they will or all your valves would have been bent in your engine but this should be confirmed. If they will clear the tops of the pistons on all earlier model years, is there any chance the valve got bent because of heavy carbon buildup on the piston tops and in the relief's?
Rob
That is a possibillity Rob, it was #4 ex valve that was bent and #4 piston top was the only piston with excessive carbon build up on it. I'm waiting on an answer as to the model year of the spare head I have.
Paul
1983 XJ1100 Maxim
1979 XS1100 Standard
1980 XS1100 Special
I'm not a motorcycle mechanic but I play one on the internet.
I checked back and I actually got it from the Yamaha dealer without problem.
Blue Giant, if you still need one give us the head and length dimensions. I'm sure someone will have one for you. Rick
Thanks Rick, I found out the spare head is off an 80G. I think mine might be an 80 bottom end with a 79 top!
Paul
1983 XJ1100 Maxim
1980 XS1100 Special
80 valves are shorter than the 78s, I have both heads and took them apart at the same time. 1/8th inch sounds about in the ballpark as far as the difference.
They sunk the valves into the head farther on the 80 and the valves are bigger...about as big as you would want to go in these heads.
The bigger exhaust and intake valves are very close together in the 80, and had to be set deeper in the head to avoid interference...thus putting them closer to the camshaft...and thus requiring a shorter stem (and higher domed pistons to make up the lost compression from the inset valves, which create more volume in the combustion chamber). No free lunch with the bigger valves...
Thanks Guy, you're my new hero. You just told me what it's taken me all day to figure out!
The engine in my bike is indeed a 1979 engine and the spare head is a 1980. Exhaust valve length in 1978-9 = 3-3/4 inches. Exhaust valve length in 1980-1 = 3-11/16 inches.
Sorry TC I didn't realize you were giving me the diameter of the intake and exhaust valves for 78-9 and 80-1
Paul
Paul
1983 XJ1100 Maxim
1980 XS1100 Special
Got a good 79 exhaust valve rolling around in the bottom of your toolbox?
Paul
Hey Paul, the only valves i have are installed in the 79 special head. Andrea is sending me some junk tomorrow perhaps he has one and can throw it in with my stuff.
Rob
