Trying to tune one of these beasts without an intake restriction of some kind either pods or the stock air box will result in rapid baldness. You will pull your hair out. Sounds like setting the idle mixture screws at 1.5 and a vacuum sync should get you back to a good starting point. 125 mains with pods on an 81 should be big enough. You can't adjust the timing on an 81 and every one I've checked that hasn't had the not adjustable bolts replaced has been spot on. You could throw a timing light on it just for grins but I'm betting the timing is OK. Your way lean if the pipes are glowing. Put the pods on and go back after it. You will get there
plugs ($$high$$) and will test them this weekent and report findings.
