Mikes XS Coil Question
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    On the coils High Output Replacement Ignition Coil Part #17-6803. How do you know which plug wire goes where? The only marking I see is a + and - on the primary side. No markings on the plug side of the coil.
    I know a few of you have done the Mikes Xs coil mod so any help is greatly appreciated.
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
  • Crazcnuk
    • Aug 2006
    • 2980
    • Hinton, AB, Canada
    It doesn't matter. These coils fire both leads at the same time.
    It's called a 'wasted spark' system. The coils fire two plugs, one cylinder is on compression and the other is on exhaust when it fires.
    The left coil fires cyls 1&3, the right 1&4.
    '05 ST1300
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      Thanks Crazcnuk!!!
      I was a little confused there.
      1980 XS 1100SG
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
        • 8894
        red/wht is pos, org and grey is neg.
        • Crazcnuk
          • Aug 2006
          • 2980
          Np, I had to put mine back on recently and I had to think about it for a moment too!
          '05 ST1300
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            Looks like you have a wasted #2 cylinder too
            BDF Special
            • Crazcnuk
              • Aug 2006
              • 2980
              heh, and I edited that, too, but then, as usual I hit the wrong button and said to heck with it!
              I usually end up editing 2 or 3 times before I hit the SAVE button, very annoying.
              '05 ST1300
              • JeeP
                • Mar 2009
                • 6
                • Montreal
                The left coil fires 1-4 and right 2-3
                Left coil is orange
                Right coil is grey
                Switch is red-stripped white and shared for both coils
                Make sure the ground is good
                • JeeP
                  • Mar 2009
                  • 6
                  • Montreal
                  From a light test tester grounded to the frame, coil wires orange and grey have +12 (and are grounded in the TCI to get the coil to discharge which gives them a 0 polarity). In a standard process, the power will be +12v/0v following firing order. You can check if your TCI is providing fire with that.
                  Red stripped white (shared by both coils) is always positive (+12v) when ignition is on, power comes from the emergency switch on the handle bar.
                  You can validate this power comes straight from the electrical harness connected in TCI unit below the seat (orange + grey are straight from there last two wires on the right of the TCI unit).
                  The only "real" ground (neg) is the coil mounting screw.
                  **Editted....it's a TCI not a CDI, and the Orange/Grey wires are negative=grounds, you just read 12V..actually should be about 9 on the grey/orange wires because the power is running from the red/white wire THRU the 3 ohm coil on the 81 machines...1.5 ohm on 78-80, and then out thru the gray/orange wires INTO the TCI where it provides the switching ground affect to fire the coils.** T.C.
                  • dbeardslee
                    • Nov 2007
                    • 4385
                    • Maineville, OH
                    MrOzz - When you attach your spade connectors to the coils slip a little piece of heat shrink over the end of the wires, connect them, and slip the heat shrink all the way over the plastic part of the coil connection and shrink it. Those connections wind up pointing forward, and it'll help keep water out. Also, when you attach your high tension wires to the coils, a little shot of wd-40 on the end of the wire will allow you to slip the donut on the wire easily, you will be able tighten the caps all the way down using only your hand, and the wire won't try to back out. I tried doing it dry the first time and broke one of the caps. My $.02.
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      Instead
                      Wow - I wish I'd done mine that way . Instead I used RTV silicone and di-electric grease outside to keep the moisture out and a small dot of petroleum jelly inside on the connections to conduct electricity and fight corrosion .
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      Iridium plugs w/ 1k caps
                      MikesXS front master
                      Loud Horns (Stebel/Fiamm)
                      Progressive fork springs
                      CIBIE headlight reflector
                      YICS Eliminator
                      • dbeardslee
                        • Nov 2007
                        • 4385
                        • Maineville, OH
                        A little dielectric around the wire after you've screwed it into the coil and before you screw the cap down isn't a bad idea. If you cut the wire ends straight, by the time you get through screwing the cable in it should have a pretty good seal between the rubber wire and the plastic on the coil. Then the donut really seals it. Still, a little extra protection never hurt anyone. The last time I changed my high tension wires I didn't bother using new donuts - just a couple fat o-rings. Dielectric would probably have been a good idea there. Next time.
                        • JeeP
                          • Mar 2009
                          • 6
                          • Montreal
                          **Editted....it's a TCI not a CDI, and the Orange/Grey wires are negative=grounds, you just read 12V..actually should be about 9 on the grey/orange wires because the power is running from the red/white wire THRU the 3 ohm coil on the 81 machines...1.5 ohm on 78-80, and then out thru the gray/orange wires INTO the TCI where it provides the switching ground affect to fire the coils.** T.C.[/QUOTE]
                          I apologize for the TCI-CDI thing .. I am often confused between abbreviation. For the voltage, may be we say the same thing .. but from the service manual page 6-11 I still see 12 volt..
                          • MrOzz
                            • Aug 2008
                            • 782
                            • Massachusetts
                            I choose not to go with spade connectors on the primary side. I soldered the wires R/W, O, G on. Used the heat shrink with the glue in it to make sure connections dont get wet. I used a little dielectric around the plug wires. Yes that help to get the o-rings over the plug wires and will help keep the water out. Thanks for the info all!!!!
                            Now all I need is the rest of my parts to get back from the paint shop so I can reassemble and go ride.
                            Ozz
                            1980 XS 1100SG
                            Pod Filters
                            DynoJet Kit
                            T.C.'s Fuse Block
                            V-Max Auto CCT
