Glass Fuses anyone?
  • 8SpadeEpiphany
    • May 2009
    • 85
    • San Luis Obispo, CA
    Glass Fuses anyone?
    I was wondering how many of you use the stock glass fuses? I've had some fuss with them to the point of carrying extra's on me at all times. It could be that the life of them was just up and needed to be replaced. Has anyone gone through and converted to modern fuses? If so, what sort of cost and labor is associated? Thanks.
    1979 XS1100 Special - "Viera"
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    There are several threads on the subject
    but this one has a lot of pics and info:
    TC's Fuse Panel upgrade
    Hope this helps
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
      • 7795
      Do a search on "fuse box", and you WILL find a few threads. TC has some nice replacement boxes for about $10 that take the "new" blade style fuses. The other way is do what a PO did on one of my bikes, and put 4 single fuse holders in place of the box. Works just as well, just does not look as neat.
      • egleaves
        • May 2007
        • 441
        • Sacramento
        I have done the fuse box upgrade (thanks to TC) and couldn't be happier. Just getting rid of those old fuses and connections cleared out some of the electrical gremlins. I even have a couple of unused slots in there where I keep spare fuses.
        I went from this:
        To this:
        I know this, because Tyler knows this.
        1980 SG
        3J6 003509
        Kerker 4-1 (sans baffles)
        Fuse Block Upgrade
        Mike's XS Green Coils
        Pods w/Homemade Velocity Stacks
        • CatatonicBug
          • 6117
          • Clinton, UT
          Yep. Definitely the easiest upgrade I will ever do on this bike. $20 total cost (including new fuses) and 1 hour of actual work to finish the job. I HIGHLY suggest taking this route!
          • 03mach1
            • 114
            • Cuba, NY
            I didnt; know about the mod on here with the newer style fuses, and I needed to get it up and running on a weekend.....so I found a glass style fuse holder at the local auto parts store...and works great for me.
            Dave
              • 8054
              Glass box replacement
              The last time I looked (it's been a while), Parts n More offered a reproduction fuse box. The cost is reasonable, but far more expensive than TC's fuse box replacement. I did the reproduction box on two XS650's because I found it easier to do on that bike. The glass holders lasted over 20 years on that vibrator! I have yet to touch the XS1100 (if it ain't broke, don't fix it), but I did source a new box from TC.
                • 2074
                I also did the TC fuse box replacement and could not be happier.I didn't put the main fuse in as when i blew it years ago i switched to an inline blade type fuse holder.
                • earl G
                  • Aug 2007
                  • 465
                  • allentown,pa
                  i use the one from parts and more. cost was $30.00. very easy unbolt old one, bolt on new one and plug in. plug and play.
                  80 xs1100G
                  • The Lorax
                    • Jun 2005
                    • 1048
                    • Riverside, OH
                    Eric, that looks nice! so that's what goes in that little black plastic rectangle on the right side of the bike, imagine that!!! have a nice day and ride safe
                    '77 KZ400s (La Putana)
                      • 8863
                      I run this type of modified gang box on both of my XS's. Everything is soldered, no plug in connectors. Main 30A fuse is in the in line holder. Left row are functioning fuses, right row are spares.
