Yikes! Me starter button broke off!
  • mfarrington
    • Oct 2007
    • 223
    • Suwanee, GA
    I was absolutely ready for my ride to work this am when that dang-ol' button just sheared right off. What are my options, long and short? XS11SF.
    Thanks!
    Mike Farrington
    Suwanee, GA USA
    Current: '80 XS11SG, '97 Vulcan 1500, '73 CB750
    Previous: '79 XS11SF, '80 XS11G, '81 XS650
    The first option is to go to the nearest salvage yard, and see if they have a used right hand switch assembly from any XS model, 400-1100. The button is easy to remove and replace.
    The next option is to order one from mikesxs.com. The starter and horn buttons are the same.
    • mfarrington
      • Oct 2007
      • 223
      • Suwanee, GA
      John, thanks for the fast reply! I figured out what'll work in the short term. I removed my key from the ignition switch, crammed it down the starter (now) hole and she sparked right up! Good thing I can remove my key while in the "on" position. Thanks again!
      Mike Farrington
      Suwanee, GA USA
        Looks like you could use a new main switch too!
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          You can also get new switch buttons off of ebay, they are on there regularly. I however am stuck with the earlier options since the PO completely removed all signs of the start button, wiring and all and wired it to a push button in the fairing. Just not much of a priority since the button on the fairing works pretty well.
          Oh, check with this guy on ebay, I have bought them from him, nice quality part. http://myworld.ebay.com/waterboy4&ss...MEFSX:SELLERID
          • latexeses
            • Jun 2008
            • 1491
            • California
            Check the ---
            Custom Parts/Services by Members post in the XS/XJ parts for sale forum...
            Polished stainless lookes pretty good..
            Everything on hold...
              • 2117
              Is the spring still there?I have an extra button if you want.All i need is an address.I have a new right side control but it is brand new.
              • chevy_338
                • May 2009
                • 49
                • minnesota
                i could use that button i am missing mine to and i do still have the spring in mine just no button
                1980 xs 11 special
                The motor vehicle action sequences depicted in this film are dangerous. All stunts were performed in controlled environments with professionally trained stunt crews on closed roads. No attempts should be made to duplicate any action,driving or car play scenes herein portrayed.
                  • 2117
                  Give me an address and it will go out tomorrow.
                  • Montreux_Blue
                    XS-XJ Guru (Deceased)
                    • 1143
                    "SWITCH ASSEMBLY with Fork Lock and Keys", for a 79, is $29 and the "STARTER/HORN BUTTON" is $6 on Parts-n-more, that is if you can afford new!
                    Famous Myspace quote:
                      • 2117
                      My button is new
                      • Montreux_Blue
                        • 1143
                        My button is new
                        My buttons not , but still works!
                          • 2117
                          Have a couple here
                          • Fix
                            • May 2009
                            • 384
                            • Lake Orion, MI
                            I just bought a new starter button.
                            And my 3 year old got ahold of the little baggie.
                            So I need another.
                            Mike C
                            Lake Orion, Michigan
                            '78 XS1100E
                            Here I am! Where are you?
                            • Ivan
                              • Jul 2008
                              • 2524
                              • Hutchinson KS
                              For the short term you can take the button out of the horn switch and move it to the starter switch, they are the same.
                              When it happened to me, i made a new on on the lathe. pretty easy.
                              Ich habe dich nicht gefragt.
