I'm seeing a pairing of 3 & 4 which has me looking for commonality. 1 & 2 are setup identically, but they're looking pretty perfect. Then again, I always go in order when I'm colortuning, so maybe it was just from them idling longer than the others at an incorrect setting. You're probably right though as it has no problems what-so-ever over 3k. If it wasn't getting fuel it would probably show up more at the top end than the bottom. OK, Randy, you talked me out of it.
The way that stutter has hung in there regardless of what I do to the carbs has me thinking it's something other than the carbs. The 'what else' is what's giving me fits. The way this problem started was I had just bumped the mains from 145 to 147.5, and everything was working fine. I rode it several hundred miles that way with no trouble at all. Then it started this crap-o-la. I went in the carbs a bunch of times to no avail, set the valve clearances, changed the carb boots (which looked to be leaking air), redid the pickup coil fix (which was failing), swapped out the TCI and rectifier, and then changed out the electrical connectors which seems to have yielded the most improvement next to the pickup coil wires. I was wondering if all the electrical issues could have caused damage to the coils, although they test out OK. I've got several more electrical connectors I'm going to get rid of, but other than that, I'm fast running out of ideas.
