Just bought a 1980 xs 11 Special
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    Hey your mechanic is probably right but it's probably the wires not the coils.There is several threads on how to fix.Terry
    1980 special (Phyllis)
    • tarzan
      • 1700
      • Chandler,Az.
      Yep,replace the wires with leads from a volt meter or get wire that is meant to flex.Then solder them in.There is a pictorial here some where.Search will find it.
      Rick
      80 SG XS1100
      14 Victory Cross Country
        Hey Newbe,
        As has been stated, the PU coil assembly is no longer available NEW. It's very rare for the actual coils to go bad, 99% of the time it's just the wires wearing cracks in them from the constant flexing, and can be replaced with test meter lead wire from RS or such! There is a tech tip on how to replace/repair the PU coil wires. Get your mechanic to view it and then do the tests on the wires, you'll probably find that they will hourglass when you tug on them with some decent tension!
        You might be able to find some USED ones on EBAY or from a fellow Xsive on here that is a quality used parts broker ANDREAS WEISS!
          • 8931
          The part # you gave (3H5-81671-10-00) is the entire PU coil assembly, which is no longer available unless you sniff out a used one. If you just need the pulse coils, they are available new from Yamaha, part # 3H5-81676-10-00, for $130. You can check 'em out here.....
            Most likely, the coils are fine, but the connecting wires are broken. Can you point your mechanic to this tech tip?
            • newbe
              • May 2009
              • 7
              Thanks to a great club member I have gotten my bike up and runninig!!
