New to 1100's, have a few questions.
  • MindWebs
    • May 2009
    • 431
    • Baldwin, WI
    i Have a 1979 XS100 special (SF i believe)
    I've installed fatboy mufflers and a uni air filter(stock air box)
    oh joy, oh joy, PO broke a float pin casting on carb 4, no big deal.
    I ground the broke tab flat and drilled and tapped the casting, then i used a stainless metric bolt and ground on the threads to flatten them to correct shape and installed it, measured correct hole height and drilled it to install
    the float pin.
    Sorry, i don't understand the picture posting thing.
    after disassembling carb's, i found the 2 differently ported emmulsion tubes
    with the low port counts on carbs 2&3 and high port counts on 1&4. I did the reading here on XS11.com, found that was wrong.
    set the floats according to gas level in bowl, PITA. what i found is that carb 4tang is extremely different then 1-3. carbs 1-3 running 2.10-2.58mm and carb 4 being 3.56mm, all measurements are on the "tang".
    Possibly a bad float, i have to check with hot water yet.
    no broken pilot screws(top, engine side of carb)
    i used my digital caliper to measure the butterfly valves from the outside of carb throat to bottem edge of valve, all are set identicly (now).
    so, now down to details....
    i have idle issues, screws set to 2.5 turns out.
    it idles poorly, lots of popping/backfiring, (blows 6 inch blue flames out of mufflers.)
    it idles low, so i increase the idle set screw, it doesn't do anything for 1.5 turns then it jumps from 1000 rpm to 3500rpm...
    i do need to check the coil pickup wires yet. (i'm planning on doing that)
    i also need to check valve clearance. (planning on doing that as well)
    does anyone have any other recomendations while i'm into these tasks,
    or perhaps live near enough to help with valve's ?
    carb's, timing, wiring, turning bolts don't scare me, but valves i've NEVER done on any of my own vehicles.
    will pay gas money and food and beverages of choise!!!
    Also in your "tech tips" You REALLY need to add a page about removing stuck jets in carbs.. it's really quite simple!!
    dissassemble carbs as best you can removing slide assembly, it's OK to leave assembled as a "bank" now make sure you've drained out as much of the gas as possible and dried with LOW pressure compressed air. now take your handy propane torch and heat the casting by the stuck jet, remove heat and spray with WD40, repeat this step 4-5 times the WD should vaporize as it hits the jet. It make lovely smelling smoke. watch it, this smoke is HIGHLY flammable. now "cool" the jet with WD40 and try removing it now.
    Remember chemisty class when the talked about different rates of expansion?
    well, here is your refresher, aluminum is lower density then brass, so it expands faster and bigger then brass. which is how the WD40 get's down in there to eat out the corosion.
    also when you have 2 different metals in contact with each other they conduct "Static" electricity differently, creating a disimmilar charge and creating what we know as a "battery". now just introduce a small ammount of water in the equasion and you will have lots of corrosion.
    A few tips here.
    WD40 contains a small amount of acid, this is how it "eats" the corrosion out.
    Never use it as a lubricant, it can CAUSE corrosion after the oil runs off.
    Gas and flame is only dangerous if you are dealing with alot of gas, or the gas can become presurized by the heat being in a sealed area. nether of these are true on our carbs. if my steps were followed.
    lastly, anti-seize compond will NOT plug your ports on all the jets, so apply it to your jets when re-assembling the carbs. this will make it easier to dis-assemble later on, hopefully in the very distant future.
    If one has allready done the worst and twisted the "notch" out of the jet, then i recomend WD40 and heat, and then try a left handed twist drill bit, to try and coax the jet out. load the drill bit in a vise grip, NOT a drill.
    that's all i have
    please let me know of any tips that may help
    Thanks
    Webs
    • 8862
    The 2 inner carb emultion tubes are different from 1 + 4 on the 79 Special, so this is normal. Did you sync the carbs with a sinc tool? Out of Sync carbs = idleing problems. Float height is 25.7 MM from carb body to the highest point of the float, with the carbs on the bench, upside down.
    • lakecountrydave
      • Aug 2007
      • 384
      • Phoenix, AZ
      Welcome!
      I cannot help you with your carbs But I can help with posting pictures. Create a Photobucket account (http://photobucket.com/). Upload the pics to your new account. Copy the "IMG Code" and paste it where ever you want a pic in your thread
      Dave
      • MindWebs
        • May 2009
        • 431
        • Baldwin, WI
        Float height
        Yup set the float height as my clymer manual listed the height..
        Nope that didn't work at all!!!
        All 4 carbs instantly overflowed and barfed gas all over the man cave.
        my octy isn't working... but still the floats shouldn't allow that to happen.
        sync..... hmm, i said i calibrated the setting. but no i don't have a sync tool yet...
        i'll get that on my next week off..
        sweet, thanks dave, I can understand those directions!!!!!!!
        • Dragon Tamer
          XStremely XSive(Deceased)
          • Sep 2006
          • 426
          • Half way between Chili and Winter Wisconsin.
          Webs,
          Seems like you have the carbs under control, but may have a vacuum leak or sync problem. Valves are not all that hard. I am only about an hour and a half away from you, need help, give me a PM and we will set something up!
          The Old Tamer
          _________________________
          1979 XS1100SF (The Fire Dragon)
          1982 650 Maxim (The Little Dragon)
          another '82 650 Maxim (Parts Dragon)
          1981 XS1100SH (The Black Dragon)
          If there are more than three bolts holding it on there, it is most likely a very important part!
          • XJOK2PLAY
            • 2099
            • Skiatook, Ok.
            Ok, Dave....
            Did ya REALLY think for one minute you could just post a pic of someone (and something, ie; da bike) SOOOOOO beautiful without properly introducing us??? Wow......
            2011 Kaw Concours 14 ABS
              Hey MindWebs, the onyl thing I would suggest to your thoughts on stuck jets is that WD40, in my experience does nto work NEARLY as well as say PB Blaster at loosening the stuck items. I can also say without a doubt that the left handed drill bit is a much better idea than an extractor in my opinion. Extractors beak off. A lesson learned the hard way!
              • cruiser
                • Jul 2004
                • 393
                • Winona, Minnesota
                Hey Dave
                How long ya had that bike? N..........ice
                XJ1100 Ruby Red
                XS1100LH "Midnight"
                1972 MGB Roadster "sold"
                • MindWebs
                  • May 2009
                  • 431
                  • Baldwin, WI
                  roundy roundy roundy
                  I agree, nice bike... wink wink nudge nudge...
                  i've read a few threads on here that make me question the valve lash
                  I don't have a clue when they were last set and i've heard they can cause some poor idle performance that's the reason i'd like to adjust them.
                  the floats have me wondering tho...
                  i've had carb's with varnish in the fuel shutoff needle jamming the springs.
                  but, this bike doesn't seem to have and varnish problems and needles seem to
                  work nicely
                  odd.. as i said i set them with the test stand method and clear hoses.
                  so floats shouldn't be an issue.
                  i've checked all the enricher curcuits for blockage with none found..
                  i also checked for vacume leaks with carb cleaner spray while running and no
                  jumps in rpm.
                  arrrggghhh... as garfield would say...
                  well, next the pickup wires i'll try to check them in the morning.
                  Thanks guys!
                  Webs
                  • chevy_338
                    • May 2009
                    • 49
                    • minnesota
                    Originally posted by lakecountrydave
                    Welcome!
                    is that your girl sorry had to say it
                    1980 xs 11 special
                    The motor vehicle action sequences depicted in this film are dangerous. All stunts were performed in controlled environments with professionally trained stunt crews on closed roads. No attempts should be made to duplicate any action,driving or car play scenes herein portrayed.
                    • lakecountrydave
                      • Aug 2007
                      • 384
                      • Phoenix, AZ
                      Not my bike nor my girl Just an example pic that I had previously posted here:
                      Dave
                      • MindWebs
                        • May 2009
                        • 431
                        • Baldwin, WI
                        Jets???
                        One more question!
                        with the opened exhast and a uni filter
                        Do i need to rejet?????
                        i've checked all my jet and i'm bone stock at the moment.
                        Help..... please?
                        • latexeses
                          • Jun 2008
                          • 1491
                          • California
                          Bikerphil,
                          I thought the 80's were jetted differently that the 78-79?
                          When I tore into my 79 carbs everything was the same.
                          Rodger
                          Everything on hold...
                            Mindwebs, look in the tech tips. There is a chart on jetting recommendations based upon what modifications have been made.
                            Roger, the 80 year, from what I have read here, was a bit of a "basterd" year. It seems the early 80 models had the same carbs as the 79 while the later models had the later carbs. So it is carb body dependent as to how they were jetted. The jetting really boils down to the main and pilot jets IIRC. If there is a through passage from the main jet tower to the pilot jet tower then it gets jetted like the earlier models with larger mains, and the bottom of the pilot gets plugged. If there is no connecting passage, it gets the smaller mains and no plug. HTH
                              • 8862
                              Originally posted by latexeses
                              Bikerphil, I thought the 80's were jetted differently that the 78-79?
                              The EMULSION tube difference on the 79 Special is what I was pointing out to MindWebs, not the jetting.
