carb swap xjto xs
  • mav2
    • Apr 2009
    • 34
    • Charlottetown,PE ,canada
    carb swap xjto xs
    hi, i just replaced my xj engine with an engine from a 79 xs1100 my question is can i use the xj carbs and will i have to rejet them the xj was a yics engine. if have to rejet, what do you recommend, or whatdid the 79 xs have for stock jetting?
    1982 xj1100
    1983 xj550
    • 8962
    You should be fine running the XJ carbs on the XS motor with no re-jet. You'll have to figure somthing out with the choke (enricher) cable though.
      Phil of course has it right that the carbs will match up to the engine no trouble.
      IF you have an XJ bike that you swapped the 79 XS engine into (be helpful if you put the bike year and model into your signature) then everything should work fine with the XJ carbs. In fact, as I understand it, the XJ has a unique enricher setup that would make it a pain to switch to XS carbs. So keeping your original XJ carbs will make the swap much easier.
      You may already know the electrical differences in the engines. There are several threads with this info in them, the TCI of the XJ does all of the timing advance control, so there is some work to do on the timing of the 79 engine IIRC.
      • mav2
        • Apr 2009
        • 34
        timing
        thanks for the replies guys, as far as the elecrical is concearned, if i change the pickup plate at the left side of the engine i should be fine correct? i have already swapped out the alternators.
        1982 xj1100
        1983 xj550
        • mav2
          • Apr 2009
          • 34
          thanks dgxser i have mysignature updated now ithink..lol also shown in my avitar is my xj1100,complete with my own custom forward controls.
          1982 xj1100
          1983 xj550
            Motors shouldn't matter where the enrichener is. It hooks to the carbs and the left handle.. Just because there's an "XS" motor in there.. nothing will change.
            Yes, if you swapped the rotor and stator cover, and also the pickup coils under the left side, you'll be good to go. Use the XJ's oil pan also so you can hook back up the oil sensor. The XS gauge is under the oil line that goes down the back side of the head into the block.. looks like a little plug.
            Are you going to use the XJ head or the XS?
            • mav2
              • Apr 2009
              • 34
              oil pan
              hmmm, never thought of the oil pan, but that is an easy change tho, so the xs had an oil gauge? maybe i can install an oil pressure guage in my vetter fairing.. that should work .and yes i did change both side covers, all the wiring is now done, ended up having to go back to the salvage yard and buying the carbs belong to the engine as the air screws in the xj carbs were unusable..
              1982 xj1100
              1983 xj550
