82 XJ1100 maxim question
    • 6765
    Need a quick answer ...what is the proper air pressure for the rear shocks? I have discovered that there was zero pressure in my shocks and \i have been bottoming out on ruts and bumps...I have put 50 lbs of compressed air in the rear shocks is this too much or too little...immediate help needed Thanks
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
  • Bigfoot
    XS-XJ GURU
    • Sep 2005
    • 1422
    • Kansas City, Missouri
    Depends on your style of riding but I usually don't put more than 40 in mine. In fact I usually run with 20 when it is just me on the bike.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
    • 0011mixam
      • Jan 2006
      • 42
      • Winnipeg, Manitoba, Canada
      According to the Owner's Manual.......
      The XJ1100 Owner's Manual recommends the following air pressure in the rear shocks:
      Solo Rider: 14-28 psi
      Rider With Passenger: 28-43 psi
      With Accessory Equipment and Passenger: 43-57 psi
      When I'm riding by myself, I keep mine at around 30 psi and that seems to work pretty well. The other thing you should check is the damping setting at the top (black thumbwheel). No. 1 is minimum damping and No. 4 is maximum damping. I have mine set to 3, which seems to be a good compromise; the rear suspension feels firm enough while cornering without breaking my back over every little bump.
      I hope this helps.
      Perry
      Perry
      '82 XJ1100 (Second Childhood)
      Frame-up Restoration
      As Original as I Could Keep It
        • 6765
        Thanks for the response...my riding has encompassed lots of bad bumps that would bottom out the shocks and transmit the jolts striaght up my back so I rode home from XSEast with 50 lbs psi and the same bad bumps were more less harsh..so it will stay at 50 psi.
