When I first picked up the 80SG, we got it running, changed fluids, did all the normal checks and then went to take it for a short test run.
I fired it up, coasted to the bottom of the driveway, put it in gear and nothing. The clutch was so tight it would not release.
Took the cover off, adjusted the clutch, and away we went. It worked good for a few days, then started to slip. Readjusted, worked for a few days, then started to slip, and so on, and soon...
I've been doing this for about 1000kms or so now. It's like the clutch rod is growing. If I adjust on the loose side, then it won't release all the way and it's hard to downshift.
Does this sound like the springs have gone soft? Or do I have something else going on. The PO told me he had been having clutch issues when he parked the bike.
As they wear down, the pressure plate moves closer to the throw out rod, and after a while, the rod will be too long since the plates are now thinner, and so it allows slipping since the pressure plate isn't able to fully compress the pack. THEN you readjust it, moving the throw out rod further away from the pressure plate so that the springs and plate can fully compress the pack and GRAB with no slipping.
