Fixed the pick up wires, Miracle Cure!
  • greatnw
    • 177
    Don't know why I waited so long to fix the pick up wires. It fixed all the hot starting, loss of power and most of the popping problems.
    Ken, TopCat and all you guys who keep pointing to that fix keep it up.
    If anyone was wondering how hard it is to tell, it isn't hard. When I pulled on the first wire it was like grabbing a rubber band! All four needed repair.
    Thanks again, that was a huge fix. I'll resync sometime over the weekend and set the idle screws when one of my buddies is in town with his gauge.
    Unbelievable the difference in power. I really like the 30mph rollout in 5th. Awesome.
    Bothell, WA
    1980 XS1100SG
  • petejw
    • 2269
    • sydney australia
    Good to hear you got it all sorted,
    I was the same with the valve clearances,
    havent checked them in 4 yrs, 3 inlet valves were so
    tight i couldnt get a feeler guage in, all adjusted, the bikes
    never run so good, especially down low and cold start idling.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • greatnw
      • 177
      Hi Pete, I was holding off on the valve clearances until I ran it for a while and had it inspected. Sounds like I need to speed that task up too!
      Bothell, WA
      1980 XS1100SG
      • petejw
        • 2269
        • sydney australia
        It cant hurt hey,
        im kicking myself for waiting so long 2 do it, laziness really,
        still cant believe the difference in the bike.
        Good luck with it, let us know how you go when you do do it.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          • 7819
          You DO need to check the valves now and then! The bucket adjusters close up, NOT loosen up. If you go too long, you can burn a valve, and that WILL ruin your ride for a while!
