Front Master cylinder repair
  • LuckyEddie
    • 166
    • Middleville, Michigan
    Gerrtings,
    I disambled the front master cylinder to clean out the spooge hole. After proper cleaning of the casting o-ring groove the old deformed o-ring no longer makes a seal. I need a new o-ring. Where can I get me one of them replacement o-rings or what is the part number?
    Thanks'
    LuckyEddie
    1980 XS1100LG Midnight special
    1982 XV750J Virago
    1976 GL1000
    1978 GL1000 Supercharged
    1981 XV920RH (chain drive)
    Sorry Eddie,
    But the Microfiche doesn't show a breakdown for that part of the MC!
    Unless someone else here posts the size, you'll probably need to take it to your local hardware store and try to find one that will fit!?
      Originally posted by LuckyEddie
      Gerrtings,
      Thanks'
      Hi Lucky Eddie,
      front master cylinder ain't got no steenkin' o-ring. Parts'n'more sells a rebuild kit:-
      Partsnmore offers premium motorcycle and ATV parts for Honda, Yamaha, Kawasaki, and Suzuki models. Shop top-quality OEM replacements, aftermarket, performance parts, and accessories at unbeatable prices. Enjoy fast shipping, expert advice, and trusted products to keep you riding smoothly. Shop now for the best deals!
      Has the complete m/c internals for $21.
        Hi Lucky Eddie,
        Hey Fred,
        You even quoted what he said, but possibly didn't read it close enough, he removed the RESERVOIR cup, and the O-ring that is around the base that seals it to the metal MC base was damaged, and he needs to replace it. IT's a part that isn't in the regular MC rebuild kit, nor in the microfiche!
        • LuckyEddie
          • 166
          Thanks TC,
          When I twisted the cup off the body, the o-ring was a mangled mess.
          There has to be a replacement o-ring.
          LuckyEddie
          1982 XV750J Virago
          1976 GL1000
          • nate
            • Sep 2006
            • 116
            • PA
            Try the local hardware store or RC shop.
            1980 XS1100g
            • LuckyEddie
              • 166
              Can anyone tell me the dimensions of a good o-ring. The one I have is toast.
              LuckyEddie
              1982 XV750J Virago
              1976 GL1000
              • CatatonicBug
                • 6117
                • Clinton, UT
                Here's a picture of one!
                The whole reservior is listed as part number 1J3-W0043-00-00-1. I know you only need the O-ring, and none of this will probably help, but I figured I put in what I could find.
                  Hey Fred,
                  Hi TC,
                  you are absolutely right. I've never thought of the plastic reservoir as a separate item and have never removed one from the m/c body. So yeah, there may well be a steenkin' o-ring that seals those two parts. Carefully measure the ID & OD & groove width where the seal fits.
                  Take those numbers to a bearing and seal shop and tell them the seal works in hydraulic fluid. They will sell you a seal of the correct size & composition.
                  • Just In Case
                    • Apr 2006
                    • 79
                    • Auckland, New Zealand
                    I took all the parts to a bearing shop that sold o-rings. The boy couldn't figure it out, but when the old guy came back after lunch he had a quick measure, got out a catalogue and ordered in the right size, which I didn't write down
                    I did get 2 as I was worried I'd bugger the first up, but it's mixed with another one and I don't know which is which.
                    1) 2.6mm thick, 46mm O/D
                    2) 2.6mm thick, 50.5mm O/D
                    I think it's number 1
                    XS1100G (3X1 000274) "Torquey"
                    You can think of a lightning bolt as essentially a really really big bug zapper. Unfortunatey, we're the bugs.
