Second Stage
The electrical part of this job is complete!
Presto! The outside of the fuel filler neck has been de-rusted and so has the inside of the tank!
For the second stage: a dilute solution of phosphoric acid will finish removing and converting any rust remaining inside of the tank and it will help to prevent flash rust as the, clean, bare, metal dries. Phosporic acid can be found in many common bathroom cleaners and it doesn't take much
7.6% phosphoric acid in 16 fluid ounces
I added two 16 fluid ounce bottles with 7.6% phosphoric acid (2.43 fluid ounces or less than 1/3 cup) to 5 gallons of water. That makes a solution containing a little less than 2% phosphoric acid.
After soaking for a few hours the tank will be drained, rinsed and the phosphoric acid will be neutralized with baking soda.
Regards,
Scott
Regards,
Scott
