Starter/starter gear teeth missing?
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    Boy, I sure have a lot of questions and comments, don't I?
    Ok, with my "spare" motor, after awhile it began to have trouble keeping the starter engaged and got to the point where it would take me 10-15 minutes to get the bike started simply b/c the motor didn't get a change to turn much before the starter freespun...it's at that time that I decided to finally fix my original motor (one cylinder was waaay out of spec) so I bored it out and put it back together.
    Between the two motors, I only had 1 good starter so I moved the starter motor over to the orignal motor. Everything was fine for a couple months and then she started freespinning every so often...today though, it was just like the spare motor was back in, freespinning and took me 10 minutes to get started...ARGH!!!
    So, any advice? I heard that I may have to replace my "starter gear" and prolly should replace the starter...
    This may sound odd, but what kind of oil are you using?
    • Snow
      • Oct 2002
      • 1041
      • Tallahassee, FL
      hmm... I am using Mobil1 15w50...oddly enough, the problems started after I finished breaking in my motor using regular Castrol 10w40 and putting the Mobil1 in...
      • sixtysix
        No XS but XSive as can be!
        • 1958
        • Central New York State
        Classic starter clutch problem caused by Mobil 1. Switch back to a semi-synth or regular oil and your problem will go away.
        Gary Granger
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          Awesome, thanks guys - I was getting really worried that I'd have to dive back into the motor
