Rear Arm Pivot Bolt
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    Rear Arm Pivot Bolt
    Is the 47 ft lbs for real on the pivot shafts. Afraid I'm gonna open the frame. Seems way to tight.
    Gene
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
    • 7830
    Gene, That is for the LOCK NUTS! The bolts are only about 5 FtLbs, give or take. What you do is even out the swing arm between the frame, and make sure eveything lines up. Then move the swing arm to be sure it is smooth and then tighten the NUTS to 47.
    • randy
      • Dec 2003
      • 4521
      My OEM manual says 43 - 52 INCH POUNDS, NOT foot-pounds. The locknut torque is 72 ft-lbs.
      • gene
        • Mar 2009
        • 267
        • Weston, Fla.
        Hope I didn't do any damage. I need to go get a 3/8" torque wrench. All I have is 1/2". I pulled the bearing out and checked them and they appear ok. Anyone know the inside frame dimension. I measured mine and it is exactly 12".
        Gene
        Gene (Florida)
        1980 XS1100SG
        Accel Coils
        4-1 Jardine Exhaust
        • gene
          • Mar 2009
          • 267
          • Weston, Fla.
          Anyone know this one.
          Gene (Florida)
          1980 XS1100SG
          Accel Coils
          4-1 Jardine Exhaust
          • randy
            • Dec 2003
            • 4521
            Set the swingarm so there's less than a 1.6 mm difference between left and right, there is no width spec in the manual.
