starter bolt
    • 2050
    starter bolt
    I decided to follow one of Randy's posts and add an additional ground.I looked on E-Bay and saw a guy was selling a spare ground kit with 4 grounds so i bought it.I took a ground and attached it from the starter to the allen head bolt by the middle drive where it connects to the negative side of the battery.I had to cut the mounting plastic tab covering the starter so i would be touching metal.Somehow i lost the bolt that attaches the plastic cover to the starter.I took off the starter and i looked but cannot find the bolt.I believe it is a M6 x 15 mm bolt.Don't know where this might be as i looked with a flashlight but could not locate it.I don't know if it landed on the floor,but could it have made its way into where the starter goes into?Started the bike up but where could it have gone?
    Is it the short bolt at the nose of the starter or one of the two long bolts at the rear of the starter?
    If you're sure it's not on the floor or kicked across the garage under the dryer lint vent hose and it didn't fall into the engine when you removed the starter:
    Check the space between the Middle Drive assembly and the engine/transmission case.
    See if it's hung up in the wiring loom or vent/overflow hoses along the bottom left and back side of the engine.
    Regards,
    Scott
      • 2050
      checked everywhere-cant find it.It is the short one at the nose of the starter.If the starter is in place,what are the chances it could go into the engine?
        Astronomically against it happening. The starter nose is sealed into the case with an o-ring so it doesn't hose up and spew oil everywhere.
        It's slightly less astronomically improbable if you removed the starter before you found the bolt but the bike started afterward without making horrible noises as the primary shaft and HyVo chain ground themselves and little bolt to shreds.
        It's in the oil pan or under the dryer vent hose.
        • latexeses
          • Jun 2008
          • 1491
          • California
          There is one other possibility.....
          It will be in the next place you look after you have made a 15 mile round trip to buy a new screw...
          Rodger
          Everything on hold...
          • b.walker5
            • Feb 2009
            • 1745
            • Invercargill, New Zealand
            Rodger
            I have something living on the floor of my garage that eats dropped parts before they hit the ground. Don't know what it is or where it hides but man has it eaten a lot of dropped parts over the years. Usually small critical stuff, and usually on a weekend when everything is shut and the weathers perfect for a ride.
            • wingnut
              • 695
              • NC
              That critter you have living in the garage comes standard with all houses with garages or basements. Its a distant relative of the zing critter. You know the one that makes that ZING noise when you take something apart and the pieces go in several directions at once. It works in tandem with the dreaded parts eater. I think there are several of them living at my place.
              wingnut
              81 SH (Daily Ride)
              81 XS 400
              Thomas Jefferson
              • b.walker5
                • Feb 2009
                • 1745
                So, is there an exterminator for these critters? Something like an excorcist, or a ghost buster, or a 12 guage or something?
                • latexeses
                  • Jun 2008
                  • 1491
                  • California
                  No such thing as extermination. The critters live in a symbiosis with wood, concrete and steel. I believe eliminating two of the three sides of the triangle is the only was to isolate them.
                  Rodger
                  • wingnut
                    • 695
                    • NC
                    It has been postulated that there are unknown physical forces at work here. It is suspected that an antimatter or black hole anomaly is present. Elimination of any of the legs of the equitation could effect elimination of the phenomenon. Caution should be exercised as deletion of any of the 3 principles could cause a rip in the continuum resulting in deletion of all matter within the affected space.
                    wingnut
                    81 SH (Daily Ride)
                    81 XS 400
                    Thomas Jefferson
                    • ppv
                      • Dec 2006
                      • 87
                      • lompoc ca
                      bolts
                      Im just the opposite.Ive got a little monster that leaves me alot of extra bolts.very seldom does he take them
                      Pete J
                      • latexeses
                        • Jun 2008
                        • 1491
                        • California
                        Wingnut,
                        ppv lives at the other end of the portal!
                        oldyam80sg,
                        Give ppv a call, I think he has your starter bolt.
                          • 2050
                          Lucky for me i keep Sears Hardware in business by buying fasteners every time i visit their store!Cant find the missing bolt still.
