I have a problem installing Progressive Springs in my '80 standard xs1000. I can't get the fork caps on no matter how hard I try (I even made a install tool out of a 4x4 post and had my wife help apply pressure while turning but it wouldn't go).
The springs stick up about 2 inches from the top of the fork tube. The instructions with the spring says that it should be 1 inch including the threaded portion of the tube. Is my 2.5+ inches of preload normal? I don't see how it's possible to install the caps with this much preload.
If it isn't normal my thought is maybe a previous owner put spacers at the bottom of the fork for more preload with the stock springs. How would I go about checking this and removing such spacers without taking apart my entire fork? Is there any way for the stock parts to be out of position that is preventing the springs from seating collectly? I'm completely lost of what to do.
Any quick help would be GREATLY appreciated considering my bike is apart on the center stand on my gravel driveway with severe weather expected today.
