Carb boots
  • Guest
    Carb boots
    when using gaskets what is the best way with yamabond which side of gasket or both?
  • tarzan
    • 1700
    • Chandler,Az.
    I wouldn't use any sealer.
    But if you are going to anyway I would put it on the head side.that way if you want to change them later it will be easier than trying to get it off the rubber.
    80 SG XS1100
    14 Victory Cross Country
    • red bandit
      • 955
      • central michigan
      The carb boot has a lip on it that seals it. I didn't use a gasket or any sealant on my new ones a couple yrs. ago. Still no leaky.
      Old ones may require a gasket or sealant??? I would try without first but that's just me.
      79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
      79 SF parts bike.
      • randy
        • Dec 2003
        • 4521
        I don't know about you guys, but I wanted to avoid leaks there at all costs. Made gaskets and used permatex aviation sealer on both sides. I don't think they'll EVER come off! But that's OK with me
        • Guest
          boots
          hey guys they are new boots with the raised lip had them on with the gasket when i pulled them off gaskets were wet all the way out and only stuck hard on the ears thought this might be where my vac leak was coming from creating my rpm hang up
          thanks
            • 8794
            I agree with Randy, I'd use sealer on both sides, then there's no chance of leakage. If you need to take 'em off later, they'll come off. JMHO
            07 Triumph Tiger 1050
            • tw1980
              • Apr 2009
              • 662
              • Bend OR
              I agree with Randy and bikerPhil.Put it on both sides tighten it down,take a paper towel and clean the excess off the inside and out,let it set a while then mount the carbs.I hate vacuum leeks more than gravel on a sharp corner.
              Terry
              1980 special (Phyllis)
              • Guest
                Boots
                hey guys looks like both sides i just want to narrow down vac leaks hope this is the one !! non hardening sealer should do the trick good thought TW on wipe the excess out inside have to go down state for 4 days i'll pick up some yamabond down there
                thanks again
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  Brokenarrow - If you use sealer, definitely do what tw suggested and make sure you clean anything that squeezes out on the inside. You don't want sealer deteriorating from exposure to gas and subsequently coming loose and getting sucked into the combustion chamber. You also don't want anything in there disrupting the air flow. Most sealers will tell you on the container the type of solvent to use for cleanup. A clean lint-free cloth dampened (not soaked) with the appropriate solvent should do the trick.
                  • Guest
                    boots
                    hey db got ya thanks
