Do you have to rejet with pods???
  • joebus
    • 104
    • Indianapolis
    The PO did a hack job of putting in spade type in place of the glass type. I will pull each one and see it there is any issues. Again it will have to wait till monday because of charging the battery. I did get it to fire up for a second. This is the first time the thing has been started in 5 months due to leaking carb, messed up oil pan and 2 gear fix.
    1979 XS1100 SF
    1981 KZ440 bobber
    • joebus
      • 104
      • Indianapolis
      pulled all of fuses and they all look good. Maybe a little build up on them so i will replace all of them once i get off work. Man i hope that fixes it, i want the bike on the road!!!
      1979 XS1100 SF
      1981 KZ440 bobber
      • dbeardslee
        • 4385
        • Maineville, OH
        Joebus - there are a few connections behind the fuse block mounting bracket as well. There's also a big white wire back there that's notorious for burning through and shorting out the works. I would take the panel loose and check the wiring behind it good.
