Kind of off topic here, but a good place to ask this.
I you go with pod filters, do the boots between the carbs and the cylinders provide all of the support needed to hold the carbs? Or is there a bracket that needs to be fashioned and installed to keep the carb assembly from falling down?
Thanks
Thanks
. But to just install jets according to some formula, or because a guy in South Florida did (even though you live in the Rockies) does not make sense. Know what your particular bike needs, and then work with that. That is tuning. If you don't know how, consult with someone who does. The results will end up better nearly every time.
. I have to agree with all of the pro podders out there. Nearly everything is better with them, if you are not going for the stock look. And, the old airbox was before the days of performance tuned boxes, so you will not lose power by removing it. (If you tune properly). I have not had any problems yet with the carb boots failing from the load of the carbs, but I could see where that may be an issue in the future. But for now, I just use it the way it is!
(Sold back to Maximan)
I still maintain that if you want your bike to run at peek, don't just install stuff as a one size fits all, but run it on the dyno and do some actual tuning. Most people (trying on their own) will eventually get their bike to run at an acceptable level, and then they stop. These people will never know how much more they could get if they did the fine tuning, and got their jetting to be "spot on". But then, just pods isn't that radical of a mod, either. Tune the right way, and you won't be sorry
