help
  • bubba88
    • May 2009
    • 6
    help
    ignore.......
  • petejw
    • 2269
    • sydney australia
    Hey Bubba,
    Welcome to te forum,
    Im assuming you have an early model xs, 78-79,
    sounds like the ballast resistor is causing your problems.
    This is situated under the tank on the left side frame rail
    its a little steet looking thing with a cpl of wires attached, i think from memory red/white?
    disconnect the wires and join them together to by-pass
    the ballast resistor, then start the engine, all good the resistor needs replacing, if this doesnt fix your problem then theres another issue.
    Let us know how you go.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • petejw
      • 2269
      • sydney australia
      so does that mean you fixed the problem?
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • bubba88
        • May 2009
        • 6
        no i started another thread with more information and a clearer explanation, i will test the resistor, i was getting a 2.2 milli ohms, i think
