For those who may have some experience with Dial-A-Jet systems on their bikes or snow machines perhaps you can tell me what you think. Dial-A-jet does not recommend using the system without an air box. I am not sure if this is due to the amount of air that would be flowing past the input nozzles or because the air flow MUST pass the input nozzle tips at 90 degrees to the tips. There’s also not enough room between the PODs and the carbs to mount the control devices.
So, I am planning on mounting the control devices on the back of the PODs and will add a curved tube to the end of each nozzle so air still passes their tips at 90 degrees. I plan to ether JB wield the additional tubes on or if the small parts can be found thread them on to the inside exposed threads of the original nozzles. I can place the control devices in a manner that will ether have the nozzle tips up or down. In the normal setup they can be placed in any configuration. The actual placement of the nozzle tips will be in the same location in the carb throat as would be the case in a normal setup.
Does anyone see any problem with this plan?
Rob
Rob
