Mikes XS Coils
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Mikes XS Coils
    I went to order the coils from Mikes XS and the are out of stock, Part #17-6803. I sent them a e-mail. They do not know when the are getting more at this time. They said I could use Part #17-6810 "Single Tower XS Performance High Output Ignition Coil 3.3 OHM Primary Resistance. 15K OHM Secondary Resistance. Capable of sustained 45KV output with 12.5v DC input. Capable of sustained 75KV output with 14v DC input. Replaces stock contact point ignition coils on All 1970 & up models and works with Pamco 270/277 engine rephase ignitions. Requires 7mm. Dia. High tension
    spark plug wires (order separate) and 5K OHM spark plug cap."
    I dont think we can. Let me know if I am correct in this.
    Thanks all,
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    You CAN use that coil! If you have a '78 or '79 with the ballast resistor, you just bypass it connecting the two wires together. I would then tape the connection so NO METAL is left exposed. They CAN short against the tank, and cause all kinds of grief!! DAMHIKIJK
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      eermm, doesnt he need the dual tower version??
      • MrOzz
        • Aug 2008
        • 782
        • Massachusetts
        My fault. The part # is for the dual tower. Copy and pasted wrong discription. The voltage and omhs is correct. part # is for the dual tower.
        1980 XS 1100SG
        Pod Filters
        DynoJet Kit
        T.C.'s Fuse Block
        V-Max Auto CCT
        • petejw
          • 2269
          • sydney australia
          If its got the dual post, those coils should be
          sweet. If you get them, let us know how they go.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • MrOzz
            • Aug 2008
            • 782
            • Massachusetts
            OK I can use a 3.3ohm coil? Just wondering cause the othe mikes xs coils were 5ohms. If i use the 3.3ohm coil all I have to do is bypass the ballast resistor on my 80? Just want to make sure. I dont want to blow up my tci.
            Thanks all.
            1980 XS 1100SG
            Pod Filters
            DynoJet Kit
            T.C.'s Fuse Block
            V-Max Auto CCT
            • petejw
              • 2269
              • sydney australia
              Yep, You should be sweet.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • MrOzz
                • Aug 2008
                • 782
                • Massachusetts
                Good News
                Hey all,
                Anyone that was interested in the Mikes XS High Output Replacement Ignition Coil Part #17-6803. They are back in stock.
                1980 XS 1100SG
                Pod Filters
                DynoJet Kit
                T.C.'s Fuse Block
                V-Max Auto CCT
