Hi guys , I finally received my fork seals today .After I took the forks apart I cannot remember how the washer that sits under the seal is suppose to sit . It isn't flat. Is it suppose to turn up or down?
fork assemble
fork assemble
BDF Special
Dyno tuned to 98 hp at the rear wheel.Tags: None
the raised portion goes up, then the snap ring, and then the dust coverAlias Larry R in Kelso WA
When in dought, punch it.
XS1100LG Precious current
XS1100SF Ruby gone to a better home
KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
when I took the forks apart there was a raise washer ,the seal ,a flat washer and then the snap ringBDF Special
I just checked my Yamaha service manual and the SH supplement, it only shows the seal, washer, snap ring, and dust cover. but either way the raised edge would have to face away from the seal. I would put it back in in the order you removed it with the raised edge away from the seal.Alias Larry R in Kelso WA
