fork assemble
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    fork assemble
    Hi guys , I finally received my fork seals today .After I took the forks apart I cannot remember how the washer that sits under the seal is suppose to sit . It isn't flat. Is it suppose to turn up or down?
    BDF Special
  • lvrsnr
    • 114
    • Kelso, Washington
    the raised portion goes up, then the snap ring, and then the dust cover
    Alias Larry R in Kelso WA
    When in dought, punch it.
    XS1100LG Precious current
    XS1100SF Ruby gone to a better home
    KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
    • tinman905
      • Aug 2007
      • 946
      when I took the forks apart there was a raise washer ,the seal ,a flat washer and then the snap ring
      BDF Special
      • lvrsnr
        • 114
        • Kelso, Washington
        I just checked my Yamaha service manual and the SH supplement, it only shows the seal, washer, snap ring, and dust cover. but either way the raised edge would have to face away from the seal. I would put it back in in the order you removed it with the raised edge away from the seal.
        • BigDick
          • 521
          • McConnell AFB, KS
          on my 80 sg it goes like this } seal flat washer snapring with the } being the raised washer
          1980 XS11SG
          Dunlop elite 3's, progressive fork springs, tkat brace
          Stock motor, airbox, carbs, exhaust
          ratted out, mean, and nasty
