Rateling noise
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    Rateling noise
    Ok, now is the time to ask, and I know i need to go in and fix 2nd gear, I have run the sea foam in the crank case and nothing changed the noise is still there, it is not the cam chain or the valves or shimes, it is a rateling noise comeing from the lower left side of the motor, my fear it is a bearing in the transmishion, kind of sounds like a bearing on a shaft going bad to me, any ideas ?
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
    Check the heat shield on the collector of the exhaust.
      Also check the connection of the VACUUM to the advance. It MUST be connected to the carb BODY on #2, NOT one of the four intake ports.
      • cowboybob998
        • Mar 2009
        • 371
        • KC MO
        Vacume line is conected, now weither it is conected on the inside dont know, will check, but would it not run right if it was not conected ?
        no heat shield 4 to 1 header
        thanks
        1979 xs1100 f
        floats @ 25.7
        1979 xs1100 F
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          If it werent connected on the inside, it would not be a source for the rattle.
          The line should be connected to the body of the carb, since that is "ported" vacuum. Meaning it is set up in such a way as the butterfly in the carb shuts off vacuum at idle. If you have it connected at the carb boot, this is open vacuum and the pulses at idle will cause the vacuum advance to oscillate at idle, making a rattling sound.
          Without putting an ear to it, I can only suggest the typical causes, which have already been covered.
          It might help if you can describe it more. is it a clunky rattle, a tinny rattle, sounds like bolts in a can etc...
          Ich habe dich nicht gefragt.
          • cowboybob998
            • Mar 2009
            • 371
            • KC MO
            Sometimes the reply does not work on here
            Anyway, the vacume is hooked up to the number two carb
            and the rattling noise sounds like a gear bounceing around a shaft to me, kind of a clunking sound I gess, dont sound like it is eating up anything, sounds kind of light not heavy any way if that makes any sence, how in the world can you describe a sound any way, lol. Now if it was a woman screming we could all relate to that, right, but it dont sound like that, thank god, oh well I gess I will figure it out sooner or later, may be when I do the 2nd gear fix I can see something.
            1979 xs1100 f
            floats @ 25.7
            1979 xs1100 F
            • Ivan
              • Jul 2008
              • 2524
              • Hutchinson KS
              Have you set the cam chain tension? Pretty simple to do, but do it right, or else lots more noise, then none.
              Pull the left cover, rotate the crank in the direction of the arrow (clockwise, these engines spin backward) and stop at the "C" mark. then loosen the nut on the tensioner, next the screw. then gently (10 INCH-pounds is the spec I believe) retighten the screw followed by the lock nut. Over tightening either will strip the threads. Lining up on the "T" or TDC mark will possibly cause the timing chain to strip.
                Just a suggestion... but if you have unknown noises in the motor, I would pull the motor and split the cases when I did the 2nd gear fix. Just flipping the bike and pulling the oil pan doesn't let you see the other things in the motor like crank bearings, starter clutches, etc.
                  Sometimes unsynchronized carbs can cause the HyVo chain, which is driven by the crank, to tension and relax, and that can cause a rattling sound.
                  • cowboybob998
                    • Mar 2009
                    • 371
                    • KC MO
                    Did the man. sink and it is ideling perty good, may have to put the xs on the back burner and get one of these ol goldwing runing so I can have a rider while i work on it, the weither is starting to turn and I want to ride, now I have a good goldwing motor, what if I put a goldwing motor in a Yamaha frame, yall gona talk to me, lol
                    1979 xs1100 f
                    floats @ 25.7
                    1979 xs1100 F
                      yeah, we'll talk to you. First, we will ask how you did it, and second, we'll ask why?
                      • cowboybob998
                        • Mar 2009
                        • 371
                        • KC MO
                        Need to get one of them runing any way so I can sell it so I have more money to spend on the xs
                        1979 xs1100 f
                        floats @ 25.7
                        1979 xs1100 F
                        • tarzan
                          • 1700
                          • Chandler,Az.
                          People pay real money for goldwings?
                          80 SG XS1100
                          14 Victory Cross Country
                          • XJOK2PLAY
                            • 2099
                            • Skiatook, Ok.
                            Hey CB...
                            Not that I'm sure this could be your problem... but something Tod and I discovered on my XJ1100 when we tore it down to do the 2nd gear fix... We discovered the bearing that's supposed to be pressed onto the output shaft in the tranny was not pressed anymore, and could walk as much as 3/4" back and forth... and much catastrophe had occured because of it. Many damaged gears. Something to check out once you get it tore down, but I'll keep my fingers crossed for you that yours is something else less tragic...
                            Regards,
                            Bob
                            2011 Kaw Concours 14 ABS
                            • The Lorax
                              • Jun 2005
                              • 1048
                              • Riverside, OH
                              Behind the clutch basket, you'll find a hex head bolt with a heavy washer attached to it...it's all one piece, Yamaha calls it a "washer bolt, it holds one of the transmission shafts in place, it is possible that it has come loose and is rattling around below the clutch, or is about to be, I found mine laying loose between the clutch basket and the kick starter (it gets torqued to 51 Ft-lbs if I remember correctly) it was loose in there for a while as it was all chewed up when I found it. just a thought, have a nice day and ride safe
                              I am the Lorax, I speak for the Trees
                              '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
                              '79 XS1100 F R (IL Barrachino)
                              '00 Suzuki Intruder 1400 (La Soccola)
                              '77 KZ400s (La Putana)
