accessory fuse
    • 2088
    accessory fuse
    Does anyone use it on their XS?I have never used mine before.Also on the fuse block metal holder-there is a tab for what looks like a wire can be hooked up to it.Anyone ever notice this?I saw it yesterday when i was looking at the connections behind the fuse block.
    • 8930
    I use them on both my Spec. and Standard. I have a wire from the pos. to a bolt mounted to the plastic rear fender well. This provides a 12V accessory terminal for my mini air compressor which I carry with me.
      The recent horn thread showed several of "US" using the AUX terminals for extra loud horns, or AUX lights, etc.! I rewired mine THRU the ATCO fuseblock so that I had the solid fuse for it as well as the regular fused circuits!
        That'll be my plan as well. I hope to eventually set up an accessory jack for things like a GPS or phone charger. I just need to get around to ordering the fuse block from TC.
        • oseaghdha
          • 1075
          • N43.02.5,W88.14.2
          Speaking of which, anyone see a good waterproof one of these anywhere ( accy jack)?
          XS1100SF
          XS1100F
          • bigray03
            • Sep 2008
            • 152
            • South-Central Lousiana
            phone charger,,,
            Carefull, they suck alot more juice than you would think. I say screw the phone.
            80special w/79special motor.Never ride faster than your angel can fly!!
