Octapus help
  • Guest
    Octapus help
    well I'am putting the carbs back on the 81 and leaving off the oct. i guess the vac adv. hose goes back to carb #2, do i block off boot 2 vac nipple ? going to use both petcocks with filters what should i plug the prime nipple with? maybe a piece of gas line with a bolt and gasket sealer? i don't want to wreck the petcock or is there a better way?
  • oseaghdha
    • Aug 2006
    • 1075
    • N43.02.5,W88.14.2
    Originally posted by brokenarrow
    well I'am putting the carbs back on the 81 and leaving off the oct. i guess the vac adv. hose goes back to carb #2, do i block off boot 2 vac nipple ?Yes. going to use both petcocks with filters what should i plug the prime nipple with? Get some neoprene caps from NAPA or something. maybe a piece of gas line with a bolt and gasket sealer? i don't want to wreck the petcock or is there a better way?
    No worries.
    XS1100SF
    XS1100F
      Yep, as stated.
      Minus the gasket sealer, this is what I did. Unless you actually turn your petcocks to prime position (which you will have no reason to do) there is nothing to leak anyway.
        A second way is to run a fuel line between the two petcocks, front to front. This is what I have done with Special Ed's bike, and he has NO problems with it. Leave just a little extra on the line, and you can lift the tank a little without removing it.
        • Guest
          It's alive!!!
          1st of all thank you for all the help she fired right right up! just have to paint the tank & side covers and if it stops raining on the road for test run and fine tuneing
          • egleaves
            • May 2007
            • 441
            • Sacramento
            I've had standard vacuum caps on mine since last year; no problems at all.
            I know this, because Tyler knows this.
            1980 SG
            3J6 003509
            Kerker 4-1 (sans baffles)
            Fuse Block Upgrade
            Mike's XS Green Coils
            Pods w/Homemade Velocity Stacks
              Eric,
              You may want to watch those vac caps. If they are not fuel rated and you accidentally move the petcock to prime and get fuel in there, they can shrivel up and crack.
