oil questions
+ More Options
Posts
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    oil questions
    my usual caveat...i have no owners manual or repair manual, so i ask you guys.
    *what is the capacity for oil in the crankcase?
    *what would cause oil to make it into the aircleaner?
    any info apprecaited.
    thnks
    redbone
    testing 1-2-3
    1980 1100 mns
  • randy
    • Dec 2003
    • 4521
    The oil capacity is stamped into the crancase next to the filler cap, 3000 cc's.
    Some oil will get into the airbox from normal blow-by into the crankcase, the blow-by gasses are recycled through the air cleaner. If you have a lot of oil in the airbox, it's possible the crancase was overfilled.
      I'll play bad cop!
      If the amount of oil in the airbox seems XSive, you might run a compression check if you have not already. If your rings are leaky, there will be XSive pressure in the crankcase which could also cause more oil to get psuhed through the breather into the air box.
      Not likely, especially if it runs decent otherwise. just another option.
        thnks
        redbone
        If you want a manual (I highly suggest having one, or both of them), you can download them for free. I host them on my website (link in my signature).
        The air cleaner is often a foam element that has oil in it. Depending on who did the oiling, there may be too much oil in it, and it'll be dripping out a bit.
          Way too much of it in the crankcase. The PO I bought Tsunami from didn't know any better, or how to check the oil level with the sight glass on the right side. He filled it to the bottom of the oil plug hole, much like what you would do with a lawn mower. It was amazing how much of it got pumped up into the airbox, ran out the vent hole in the bottom of the airbox, pooled on top of the motor, then rolled off onto the hot exhaust each time I turned a corner.
          A similar effect happens when you have leaky petcocks and float valves, and most of a tank of gas floods through the carbs into the crankcase.
          • Trainzz
            • Apr 2009
            • 215
            • KS
            Free manuals?!!!
            Went to the website, downloaded the manuals, 2-side printed them, three ring binders. They are on my workbench now. Jeeze, sometimes the OCD works in my favor.
            Lee aka trainzz
            I am my inner child!!
            I have no idea how you managed to make that connection within your brain, but I applaud whatever cellular mutation just took place.
            1980 XS11 Special-"Thunder Pig"
            1980 XS11 Special-"Crazy Trainz" (project bike)
            1979 Xs1100 Standard ( parts,parts,parts)
              Glad I could be of service!
              • redbone
                • Oct 2007
                • 244
                • Waynesboro pa
                yes yous were rite
                to all.....yes there was way to much oil in the crankcase and gas for that matter. the oil was flowin up and the gas was flowin down. smelled like an oil refinery when i drained the engine. seems o.k now.
                cata, i tried to find that link to the manual...was not succesful.
                will try again rite now
                thanks again all
                testing 1-2-3
                1980 1100 mns
                • redbone
                  • Oct 2007
                  • 244
                  • Waynesboro pa
                  got it that time
                  hey cata,
                  got the rite link that time. to much of a hurry yesterday'
                  thanks again
                  redbone
                  testing 1-2-3
                  1980 1100 mns
