kickstand vs. centerstand
    It's just too bad that the sidestands are so cheezy. I have been considereing looking for a different model sidestand, like a harley or a goldwing or something with a bigger footprint. Has anyone done this already?
    BTW, if you loose the centerstand, it is a good tool for your garage. Just slip in the pins and spin the nuts on a few turns and you are ready for maintenance! It doesn't have to fit yoy exhaust 100% for that.
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      I use the center stand most of the time...only use the sidestand if the bike is going to be parked for ony a few minutes, or when getting fuel. To many cases of bike tipping over on hot asphalt or unstable surfaces.
      When I did use the side stand more I had a rectangular piece of 3/16 steel (4x4 or so) with a hole drilled in one end. A light cord was tied through the hole, so I could sit on the bike, flip up the stand, then pull the plate up with the sting and put plate and string in the Vetter left-hand pocket.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • Jdwags
        • 232
        • Rathdrum, Idaho (nort of Post Falls)
        I had no center stand on the Mongrel when I got him, found one on Ebay and glad i put it back on..
        Extremely scarey drive up the block when i see the Mongrel
        tire flat (after a ride) and its lodged between the rocks and the pickup (the wrong side up?)
        I end up using it most of the time.. i also don't spill fuel as ofte when refueling--- gotta try to keep that faded paint job as nice as possible..
        It does clash with the slip on's, but i think i have figured out the slight modification to the tab to solve that problem..
        Now where did i put that sledge hammer...????
        jeff "Wags"
        Bothell, Wa
        79sf mongrel
        79sf rusty
        79 partsbike almost complete
        • schpiff
          • Mar 2003
          • 175
          • south central Wis
          nuthin like a torch to cure the metal blues......
          '81 sh " Maime" The Nature of The Beast
