140 mph speedo odometer roll back
  • BigDick
    • 521
    • McConnell AFB, KS
    So I just bought a 140 Mph speedometer from renegade_xs11g, (great experience buying from him, not one complaint). I would LOVE to roll the odometer back so it matches my 85 mph speedometer. Does anyone know an easy way to do this without taking the bezel off/prying it apart?
    1980 XS11SG
    Dunlop elite 3's, progressive fork springs, tkat brace
    Stock motor, airbox, carbs, exhaust
    ratted out, mean, and nasty
  • Crazcnuk
    • Aug 2006
    • 2980
    • Hinton, AB, Canada
    No, they are made tamper proof for legal reasons.
    It can be done, I think, but requires a complete disassemble.
    '05 ST1300
    • BigDick
      • 521
      • McConnell AFB, KS
      How about hooking the speedometer cable to a electric drill or dremel tool and just rolling it over? Does this keep the numbers lined up? I've seen on other speedometers where they've rolled over but the numbers were slightly misaligned.
      1980 XS11SG
      • Crazcnuk
        • Aug 2006
        • 2980
        Have you actually seen this, or heard of it.
        I think it's more of an urban myth, since you would wear out a drill or two going for 50-60,000 miles or more?
        '05 ST1300
        • BigDick
          • 521
          • McConnell AFB, KS
          Never heard/seen it, but it was the only thing I could think of other than taking the speedo apart.
          1980 XS11SG
            Hey Dick,
            What Craz was talking about was the misalignment part when it rolled over, not the technique of rolling it over with a drill. Instead of a drill, perhaps a DREMMEL tool with a fan blowing on it to help keep it cool, smaller motor, less energy used, and can spin to 10k rpm. I haven't done the math on the rotations of the cable part at that rpm and what road speed it would show, but would still take quite some time to roll it over as well as then take it back up to where he wanted it to be!? I don't know if it will work rolling backwards. I know the speedo won't display, but not sure if it would damage it, but I don't think so, thought it was just magnetic fields that pull the speedo pointer around, not any actual moving parts contacting the needle!?
            If you do try a dremmel...btw I don't think they are reversible like some drills are, so it might not spin the correct direction anyways, but IF it could spin backwards, would spin it forwards first to see what road speed would be indicated at what dremmel rpm, so you might know what would be a safe speed to have the dremmel running at!?
            At 100mph, that's 1000 in 10 hours, 2,400 in 24 hours, so might take several days to roll it back or over!
            • BigDick
              • 521
              • McConnell AFB, KS
              I gotcha, sorry about that, I have seen odometers slightly misaligned after they roll over but only on cars and trucks.
              as a side question, how in the world are you supposed to get your front wheel off without taking off the fender also?! My fender's already off (well nearly, had to stop due to busted knuckles ) but it'll be nice to know for when i put it back on. and again, do i need to do anything special to the speedometer drive like pack it with wheel bearing grease or something? Thanks!
              1980 XS11SG
                Just to note... hooking a drill up to the odometer does and will take the miles off... but as TC stated.. it would be a long process. I used a regular drill to try it and on high, it was showing like 15mph when I put it on forward. lol. I had a broken speedo cable that I chucked into the drill to stick up into the speedo housing.
                • BigDick
                  • 521
                  • McConnell AFB, KS
                  yep, my dremel has a special tip for use with the long handheld wand thingy, (too lazy to post pictures of such) and it does take off about .1 mile every second, so it's not too slow. lol 13973.6 miles on the stock one, 31239.5 on the fancy one, makes 17269.9 to take off, so only about 172659 minutes or 2877.65 hours or 119.9 days of that dremel constantly running. (if my math is correct )
                  1980 XS11SG
                    • 7795
                    On the Specials, you NEED to remove the calipers.
                    • XSPastor
                      • Oct 2007
                      • 602
                      • Gaithersburg, MD
                      Bust it open!
                      I think the best way would be to take it apart. I've had both my tach and speedo apart and, if you are careful, you can re-crimp the bezel and it looks exactly the same as before when installed. No visable evidence that it was ever opened. I believe there is a tech tip that explains how to take one apart.
                      Tim Ripley - Gaithersburg, MD
                      23mm float height
                      120 main jets
                      42.5 pilot jets
                      drilled stock airbox with K&N
                      Jardine 4 to 1 Exhaust
                      spade fusebox
                      1st and 2nd gear fix
                      • BigDick
                        • 521
                        • McConnell AFB, KS
                        yep, I ended up removing both calipers, and the fender so i could rotate the lower fork tubes to work the wheel out. My Clymer said I only had to remove the right side caliper. ><
                        Yeah, I've read the tech tip but I'm leery of opening it up and messing it up when the odometer is the only thing wrong with it, and that's not even really a problem. Thanks though.
                        1980 XS11SG
                          Either it's late, and I'm not thinking right, or your math is a bit flawed. A tenth of a mile every second means 6 miles a minute.(360 mph!! WTG!!) 17269.9 divided by 6 equals 2878.32 minutes worth.. or.. @ 48 hours.
                          Still a long time running.. but not as bad as you thought.
                          • BigDick
                            • 521
                            • McConnell AFB, KS
                            ROFL, and these are the people who are doing math for the United States Air Force folks (that's me! ), maybe I need a pot of coffee to get my brain in gear? The funny thing about it going the 360 Mph is since it was going backward and running the odometer down the speedo needle wasn't moving at all. (also that was at about half speed on my dremel--too lazy to go check the manual and see rpms)
                            1980 XS11SG
                              Well... I guess just be glad the Dremmel turns the direction it does since they aren't reversable... unless you wanted to run it through the OTHER way and go 83k miles! lol.
