Carbs size
    Hey JC,
    The front outlet of the petcocks are PRIME, so plug those off. Use the rear outlets, otherwise you won't have a RESERVE when you need it!
    IF you have old cracked intake boots, they are most likely cracked only on the outside, the insides...they are double walled are usually in good condition and you can still use them even though they are aesthetically unappealing! You can slather a bunch of black RTV on them, wrap them with rubber plumber pipe/hose sealing wrap, etc.!! SO...you shouldn't have to wait to get our replacement set of intakes before you can put the carbs on and try to fire it up.
    However, have you CLEANED the new carbs yet!? You can't go by the seller's comments of what they have done to them. IF the pilot circuit isn't clean, it won't idle properly or provide a good low rpm throttle response!
      One of the carbs on my SG had a broken float post and helped me to a fire. I sourced a pair of carbs from a XS650SH. I replaced my damaged carb body with one from the XS650. They are the same.
      Keep in mind that the XS650 is far more plentiful than the XS1100 and the XS650 folks are always upgrading to round slides, flat slides, Dellorto pumpers, etc. This keeps stock carb parts plentiful if you know where to look.
      Hey Marty,
      The thing that folks need to realize is that you used the 81model 650 carbs, which are the later model type with the larger vacuum diaphragm slide assembly, but is NOT the same as the 78-79 series carbs, so they are not completely interchangeable depending on what year carbs they have!!
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        Right On
        T.C. - You rock
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • JC FC
          • Mar 2009
          • 49
          • Salt Lake, UT
          i cant use the old ones, they are torn, wont even hold the carbs up lol!
          so i still gotta wait
          yeah, the guy who owns the boneyard i goto told me all about it cleaning them when i got home, i have cleaned half of them, had to goto work other half i will do today XD
          Originally posted by Axel
          T.C. - You rock
          yes, yes T.C. does
          '79 XS1100SF
            • 7942
            XS650 carbs
            You are correct. To use XS650 carburetors on the XS1100, the model years must correspond and one must be prepared to do a lot of dismantling in order to link up the butterflies. It is, however, a plentiful source of parts as XS650s greatly outnumber XS1100s. Also consider the fact that so many XS650 enthusiasts reject stock carburetors in favor of something else.
