I have a 1980 XS1100G. I have installed pod filters, and rejetted the carbs. I did take the carbs off and did a general cleaning of the. They seem to be in good condition. The bike shows a little over 61,XXX miles on it. Here is what I did I cut off about 6-8 inches of the back to put on a solo seat, after I did that the exhaust didn’t look really good sticking off of the sides, so I cut them off. Just below the foot pegs.
The problem is the bike is missing all around but really noticeable around 4-500 rpms. Reading through some other threads There was a comment that the engines needs the back pressure of the muffler/exhaust to make it runs properly. I do not mind how loud it is or that it back fires like a shot gun every now and then. but do i need to have that back pressure to run smooth.
It does idle and starts ups with no problems.
I have replaced the coils, wires and put in new plugs—good spark
Redone the timing wires
Replaced the all the hoses.
Did a compression test with a warm engine with throttle wide open and
1-160psi 2-130psi 3-160psi 4- 155psi
I have also sync the carbs, I have the dial type not the mercury. I sync to the 3rd carb witch was just over 20 (psi?) now all the carbs are now sync to 20 when I raise the throttle to 4 -500 rpms the dials all move and stay together.
I am missing something or do I need to get another exhaust or should I retry to clean the carbs and take out everything and clean it and put it back together??
SIDE NOTE::
I was having problems with my head light not turning on and when I open the “ignition box” someone had done some modifications to it. So I ordered one off ebay and right when I plugged it in I started the bike and the headlight came on.
For what ever reason I still can get the turn signals to work. They have never work since I have owned the bike. The come on but will not blink. The funny thing is when I turn off the bike and then turn on the hazard switch they all blink and I can hear the relay switch.
If you have ideas on that I would a appreciate it.
I will post some pictures when I get everything back together, (everything is black, everything)
SIDE NOTE::
If you have ideas on that I would a appreciate it. I will post some pictures when I get everything back together, (everything is black, everything)
