I'm betting a Virago or Maxim.
Possible parts bike
1997 Jeep Cherokee 4.5"lift installed -
That i don't know.You would have to maybe get on a maxim or virago website to tell you rim size,etc about the bike and related parts swap.Good luck!1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
I place my bets on an 81 Midnight Special. Has the same wheels and reflector for sure.
-From the internet
Acta Non VerbaComment
Well Andy,
I hate to say it but with the drum brake rear wheel, it won't work with your 11. The drum brake portion is molded into the wheel hub, whereas with the 11, the rotor just bolts onto the hub. The front wheel will probably work, most are 19" in that era, wouldn't hurt to ask the guy for the size of the front wheel, but you would have to find another swirley rear wheel from an XJ or MNS. I was looking thru the microfiche but couldn't find an exact model match in the 82 or 83 models. The photo also looks like it only has 1 caliper up front. For these bikes it's not a problem putting on the 2nd rotor because Yamaha usually cut the rims for mounting dual rotors.
Also don't know if you would be willing to use brake drum rear vs. disc, but also don't know if the driveshaft spline assembly would mate, or if you would be able to swap one from the XS11 onto this one??
T.C.T. C. Gresham
sorry fellas. Misread. I was going by the pic. Just looks like a dirty disc 2 meUnited States Merchant Marine Academy, Kings Point, NY
Here's the VIN JYA22R003DA101438\
From doing my research:
1983 YAMAHA
XJ750M
VIN:JYA22R003DA101438
World region:Asia
Manufactured in:Japan
Year:1983
Make:Yamaha
Model:XJ750M
Body style:Road / Street
Drive type:RWD
Cylinders:4 Cylinders'80 XS 1100 Standard Comment
Thank God it was not!-A guy I worked with had a 920 Virago-pure crap-Noisy,drove like crap and had a problem with the starter.Read somewhere they had to have work done to the starter to fix the problem.1980 XS1100 SG
From the VIN Look up this is what I found.
Hope it helps
1983 YAMAHA
XJ750M
VIN:
JYA22R003DA101438
World region:
Asia
Manufactured in:
Japan
Year:
1983
Make:
Yamaha
Model:
XJ750M
Body style:
Road / Street
Drive type:
RWD
Cylinders:
4 Cylinders
OzzFour wheels move your body, two wheels move your soul.
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCTComment
