Replacement Spings for Rear Shocks
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Does anyone know if you can get replacement springs for the rear shocks? The ones I have are rusted really bad due to PO always leaving the bike outside and not taking really good care of her. I have cleaned them up but the rust goes deep and my fear is having a spring break.
    Thanks again all for your infinite wisdom.
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
  • kirmit77
    • Mar 2009
    • 464
    • Kingwood, TX
    spring break
    i know i never fear spring break! that is one of the best times to go to the beach, ride around, do some wheelin, you know have fun!!!
    Austin Ingalls
    MIDNIGHT FURY
    XJ maxim rear air shocks
    KERKER 4-into-1 exhaust
    Pod Filters
    Money pit.......
    BLACKED OUT
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      LOL. Not really what I exspected as a answer. Still funny though.
      1980 XS 1100SG
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        You can find Progressive shocks on E-Bay cheaper than you can buy replacement springs sometimes. Or have your springs powder coated black or chrome colour.
        BDF Special
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          The Progressives are a little out of budget The springs in my opinion are to far gone to have refinished.
          Thanks for the input though.
          1980 XS 1100SG
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
          • Montreux_Blue
            XS-XJ Guru (Deceased)
            • 1143
            • Longitude: -85ยฐ 57' 43" Latitude: 37ยฐ 52' 55"
            $75 a piece on Parts-n-More! Try andreashweiss (Andreas), he ALWAYS has parts.
            Famous Myspace quote:
              Progressive sells replacement springs (only) for this bike, but they're not particularly cheap (about $80-90). They also sell complete shocks; about $250. So Ebay would be a good place to look for that 'budget' deal.
              If you decide to reuse the stockers, be very careful about powdercoating them. Most commercial coaters sandblast the parts to clean/prep them, and that will 'stress relieve' them... that basically means that will remove the 'spring' and they'll sag badly when put back in service. You also have to be careful about curing the powdercoat; a 'normal' cure temp will also remove the spring, with the same results. Cure the coating at no more than 325 degrees. It won't be as durable, but you won't ruin the spring.
              I had the same thing happen to mine (peeling chrome), and I cleaned 'em with chrome polish and a stainless steel 'toothbrush', then used a small wire wheel on the really bad spots. A good coat of paint, and they've held up pretty good since.
              '78E original owner
              • tinman905
                • Aug 2007
                • 946
                I bought my Progressive for under $70.00 there are deals on E-Bay if you have the time something will show up .
                BDF Special
                • MrOzz
                  • Aug 2008
                  • 782
                  • Massachusetts
                  What model Progressive shocks are you all using? Any recomendations? Also are the stock shocks the same for the xs? For fitment any ways.
                  thanks all
                  1980 XS 1100SG
                  Pod Filters
                  DynoJet Kit
                  T.C.'s Fuse Block
                  V-Max Auto CCT
                  • tinman905
                    • Aug 2007
                    • 946
                    I have a set of 412's on my bike . I took the shims from the old shocks for the bottom and used 1/2 copper pipe for shims on the top bolts . I was a bit concerned about the copper being to soft but everything seems fine so far.
                    BDF Special
                    • MrOzz
                      • Aug 2008
                      • 782
                      • Massachusetts
                      Interesting. Would any 11.5" shocks work as long as I shim them to fit properly?
                      Thanks again.
                      1980 XS 1100SG
                      Pod Filters
                      DynoJet Kit
                      T.C.'s Fuse Block
                      V-Max Auto CCT
                      • tinman905
                        • Aug 2007
                        • 946
                        Thanks again.
                        I have bought 2 set of progressive shocks 412's and 418's that were for harley's and got them to fit with out much trouble.
                        BDF Special
                        • andysutt
                          • Mar 2009
                          • 187
                          • Conway AR
                          I should have a set of springs come the end of the week. If your interested in me PM me and we can work something out
                          '80 XS 1100 Standard
                          • Ivan
                            • Jul 2008
                            • 2524
                            • Hutchinson KS
                            You could get some air shocks from an XJ and use them. That's what I am looking for, since my fat butt can compress the rear springs pretty easily going over curbs and retaining walls.
                            Ich habe dich nicht gefragt.
                            • Crazcnuk
                              • Aug 2006
                              • 2980
                              • Hinton, AB, Canada
                              That's what I would like too. Air is infinitely more adjustable for all kinds of loads/conditions.
                              '05 ST1300
