I have two sets of needle and sets, trying to figure out what ones to use, the only deference i can see is that the plunger on one set of needles will go all the way in the needle and the outher will only go about 2/3 the way, the ones that only go part way seem to have a stronger sping in them, my thinking is the ones with the stronger spring would be better, what do yall think ?
needle & seat
The ones that go only 2/3 most likely have dirt in them . The spring should compress all the way if you push down on it.BDF Special
Are you talking about the carb float valve? They don't have springs. They do have a retaining clip. Maybe this is what you're referring to? Or maybe you're talking about the diaphragm spring and the needle on the bottom of the carb slide? Help us out here.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix
Oh, I think I get it now. You're talking about the spring inside the needle? Definitely use the ones that go all the way down and up. If you soak the others, they might free up...Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
I think the ones that dont go all the way down are the ones that came out with the bike from what i can tell, this bike only had 20,000 miles on it, I need to compare a pair of needles that are known good that are the oridgenal oem parts because I am haveing a hard time beleaveing that all four just happen to get that much dirt in them at the same time, they are all consiatant about how much they travel they have, I have them soakingin pb blaster right now, let them soak over night and see what tomorow brings.
thanks guys1979 xs1100 f
142 main, 45 pilot, Jardeen crosover 4/2, no air box
floats @ 25.7
1979 xs1100 F
1978 gl 1000 goldwing
1981 gl 1100 goldwing
!986 venture royale 1300
Just an ol long haired country boy, come to town to spend some egg money
when ya get bucked off, get back on
Yep
I agree. If they're all the same, they're probably just a different kind. Probably doesn't matter which set you use as long as the tips are good and they don't leak.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
